LS/VTEC question
Old Feb 12, 2005 | 06:52 AM
Shiro Z31-T's Avatar
Default LS/VTEC question
I'm debating doing an LS/Vtec or All motor b18c1 and was wonding if you could get similar results from just putting an LS Crank and rods in a gsr block... instead of tapping an LS block for a vtec head. is there any major difference between the gsr block and ls?
I figured that an LS makes more torque due to a longer stoke but i dont really know for sure. anyone?
Old Feb 12, 2005 | 07:15 AM
D-Rob's Avatar
Default Re: LS/VTEC question (Shiro Z31-T)
Pretty sure that's the difference.
LS = longer stroke.
...Although I'm not too sure if you'll be able to retain the oil squirters in the GSR block with the LS crank. Some else chime in?
Old Feb 12, 2005 | 09:03 AM
krazie1's Avatar
BANNED
Default Re: LS/VTEC question (drobinson)
yes u can with sotck internals but once u go aftermarket rods
u can't
but once u get the pistons aftermarket theere is no reason for the squirters the pistons are made of a low temp material that won't heat up
Old Feb 12, 2005 | 10:10 AM
jdmcx's Avatar
Default Re: LS/VTEC question (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">yes u can with sotck internals but once u go aftermarket rods
u can't
but once u get the pistons aftermarket theere is no reason for the squirters the pistons are made of a low temp material that won't heat up</TD></TR></TABLE>
2nd that
Old Feb 12, 2005 | 01:29 PM
Default Re: LS/VTEC question (jdmcx)
So if I choose to build up the GSR block then throwing in aftermarket LS rods and crank will give me similar results to ls/vtec?
Are there any differences in bore between LS and GSR?
Basically I'm trying to figure out what would be a better solution... I've heard a shoddy LS/Vtec job won't be reliable at all so I'm not sure if thats something I want to risk. So if I can get similar results by putting LS internals into a GSR block then that seems like the easiest way to go...?
Old Feb 12, 2005 | 02:01 PM
5STAR3's Avatar
use your b18c.
use an ls crank.
use stock ls rods.
use any b-series piston you want[pr3,p30ctr,itr whatever]
still use the b18c block girdle.
this will give you the same thing as an 'lsvtec' but you are just using a better block to start with.
Old Feb 12, 2005 | 02:46 PM
thevanitygroup's Avatar
Default Re: LS/VTEC question (envision2teg)
^ second that. You'll get the LS/VTEC torque without the oil failure sometime attributed to LS/VTEC setups.
egboy94
Sep 2, 2009 03:24 PM
98GSR-Turbo
Oct 14, 2008 09:22 AM
nebulight
Nov 9, 2006 07:49 AM
trucdoken
Mar 12, 2005 09:37 PM
Kingsperformance
Feb 25, 2004 02:16 PM
