What motor now.!?
After being on the tracks with my swap. I think it's a piece of crap. Seeing a Rsx smoked the living crap outta h22 b18c gsr type b18a1 (ls vtec ) I'm thinking about doing one of those higher more horsepower swap. Which one would u go with!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMmniTz »</TD></TR><TR><TD CLASS="quote">After being on the tracks with my swap. I think it's a piece of crap. Seeing a Rsx smoked the living crap outta h22 b18c gsr type b18a1 (ls vtec ) I'm thinking about doing one of those higher more horsepower swap. Which one would u go with!?
h22 b18c gsr type b18a1 ?
ummm.... what are you saying?
you can do a ls/vtec but not with a h22 head or anything like that.
what si your setup and what is your budget for a motor build. you want to do na or fi?
best bang for buck imo...ls/vtec + lots of boost
can i do a poor man gsr? with a gsr block and si head? will that work!? it's almost the same as a ctr i believe!? correct me if i'm wrong.!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMmniTz »</TD></TR><TR><TD CLASS="quote">can i do a poor man gsr? with a gsr block and si head? will that work!? it's almost the same as a ctr i believe!? correct me if i'm wrong.!!</TD></TR></TABLE>
Its called a poor mans type-r
You get a b18c block with a b16a head (pr3 head is best for this)
Gets you almost a type-r motor without that crazy price
WTF, just do a B16 swap, they can be found easily and cheap. OR you could always boost your current set-up. Im not sure what your set up is right now but those are my suggestions. Good Luck Man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turn2quick4u »</TD></TR><TR><TD CLASS="quote">yeah you can do that any b series head will work if thats all you got go for that will be a dope little set up.
even the imfamous b20a3/a5 prelude heads?
