For Those of You With Teg Dash in EG USING Teg Harness
Hey Guys,
For those of you that wired in your integra dash and used the integra dash harness you had to pin integra wires to the one civic plug that connects to the fuse box.
Can someone take a picture of that civic plug that visibly shows the integra wires being pinned into the civic positions?
This would be a great reference for people that want to do this mod in the future.
From: Why so you can pretend like youre interested, FL/OK
It's still going to depend on which cluster and plugs the person has. I can tell you I have in total had three different clusters in mine, at one point, two different Integra ones for testing. Using the same plugs between a 1994-97 cluster on a 1998-01 cluster will not work. One of the clusters will go haywire.
I have a 98-01 cluster. I don't know what year the harness is from however. If my harness turns out to be from a 94-97, it won't work?
Yes.
1998-01
Thanks to slomob18b from a long time ago.
1>16=left to right
01=yellow/white=fuel gauge unit
02=light green/red=door-open indicator light
03=
04=blue/white=low fuel sensor
05=
06range=maintenance reminder light/tcm/ecm/cruise control unit
07=green=tailgate-open indicator light
08=red/blue=seat belt reminder light/driver's seat belt switch
09=red=dash brightness controller
10=red/black=fuse for gauge light
11=black/yellow=charging system light
12=white/green=hazard warning light
13=green/blue=left turn signal switch
14=green/yellow=right turn signal switch
15=red/green=fuse for high beam indicator light
16=green/red=brake system light/parking brake switch
For some reason I could not locate 3 and 5. Nevertheless i hope this helps you find what you are looking for.
01=pink=hazard warning light>harzard warning switch
02=pink=maintenance reminder light>maintenance reminder unit
03=
04=yellow/blue= fuse?
05=red/blue=cruise control unit/light
06=black
07=yellow/green=engine coolant temperature gauge(ect)
08=
09=white/blue=charging system light>alternator
10=
11=yellow/red=low engine oil pressure indicator light>engine oil pressure switch
12=green/orange=malfunction indicator lamp
13=blue=ignition control module>tachometer drive unit
this was all that was listed in the diagrams.
1994-97
Thanks to SSBP DC2 from long ago.
the 16 pin connector is called the B connector
the 13 pin connector is called the D connector
look at it from left to right with B1 (or D1) being the #1 pin on the left handside, with the plug right side up (how it's suppose to be when it's plugged into the gauge cluster and you're looking at it from the driver's POV).
B1 = seat belt reminder
B2 = door open indicator
B3 = fuel gauge unit
B4 = low fuel light
B5 =
B6 = speedometer drive circuit
B7 = hatch (trunk) open indicator
B8 = abs indicator light
B9 = gauge lights (from fuse)
B10 = gauge lights (from dimmer)
B11 = charging system light (from battery)
B12 =
B13 = left turn indicator
B14 = right turn indicator
B15 = high beam indicator
B16 = parking brake light
D1 =
D2 = maintenance reminder
D3 =
D4 = cruise control (from fuse box)
D5 = cruise control (from cruise control unit)
D6 = ground for high beam indicator
D7 = coolant temp gauge
D8 =
D9 = charging system light (from alt)
D10 =
D11 = low oil indicator
D12 = malfunction indicator
D13 = tachometer driver circuit
D2 and D9 were designed to be isolated on purpose, take a guess why
this is for reference only. It may be right and it may be wrong....but it's taken straight out of a honda service manual for 95 integra GSR. i take no responsibility for your action should you decide to be creative. Have fun
https://honda-tech.com/zerothread?id=430290
https://honda-tech.com/zerothread?id=430179
1998-01
1>16=left to right
03=
05=
03=
06=black
08=
10=
1994-97
B4 = low fuel light
B5 =
B12 =
D1 =
D3 =
D8 =
D10 =
The 1994-97 cluster plugs 16pin layout also explains, why in the other thread he was having problems with the fuel gauge and the ebrake, according to pin one.
I am in the same boat as this guy. I have a 95 underdash teg harness to match my dash, a 95 cluster with a million miles and a 97 cluster with a lot less for my EG of course. I think the 98-up clusters pose the problem becuase i read somewhere that the ECU generates some of the info on the 98-up clusters. Resulting in those clusters going haywire...Whereas the 94-97 clusters get all their info from the sensors/wiring and not from the ECU.... This is what i heard tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">I have a 98-01 cluster. I don't know what year the harness is from however. If my harness turns out to be from a 94-97, it won't work?</TD></TR></TABLE>
The harness isn't what really matters, basically those are just wires if there is nothing plugged into them. It's the led sending points on the back of the cluster that make the difference. Initially, I had heard there were problems getting the 98-01 or 99-01 Integra Clusters wired up, but I don't believe that to be the case. I believe you just have to change around the ordering of the cluster to match. What specific problems are you having with your cluster once wired up using some of the diagrams you have found on H-T?
Haywire speedometer and rpm gauge if you turn on the turning signals or something along those lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s »</TD></TR><TR><TD CLASS="quote">I am in the same boat as this guy. I have a 95 underdash teg harness to match my dash, a 95 cluster with a million miles and a 97 cluster with a lot less for my EG of course. I think the 98-up clusters pose the problem becuase i read somewhere that the ECU generates some of the info on the 98-up clusters. Resulting in those clusters going haywire...Whereas the 94-97 clusters get all their info from the sensors/wiring and not from the ECU.... This is what i heard tho.
Heard that as well in a post a few years back, but not certain how whether the problems can be overcome or not.
</TD></TR></TABLE>Heard that as well in a post a few years back, but not certain how whether the problems can be overcome or not.
That diagram from the other post was fine. I think BlueIntegra posted it. Just use to top diagram and keep your eyes on everything on the left hand side.
Here's a diagram from Mr. Poison.
Red/Blu will be left out
Blu/Red will be left out
Yel/Grn > Yel/Grn
Yel/Red > Yel/Red
Yel/Blu > ORG
Blu > Blu (this wire has two grey dots along the wire)
Prpl/Grn > Grn
Blu > Blu (this wire has one grey dot along the wire)
Grn/Org > Grn/Org
Red > Red
Blu/Yel > Blu/Yel
Wht/Grn > Wht/Grn
Brn/Blk > Brn/Blk
Red/Grn > Red/Grn
Then splice the Yel/Blk wire to the Yellow wire on the green plug to supply power to the integra hazard switch. This will make your turn signals work.
The thing about this is that I'll have wires left over. How do I figure out what to do with them?
Yel/Grn > Yel/Grn
Yel/Red > Yel/Red
Yel/Blu > ORG
Prpl/Grn > Grn
Grn/Org > Grn/Org
Red > Red
Blu/Yel > Blu/Yel
Wht/Grn > Wht/Grn
Brn/Blk > Brn/Blk
Red/Grn > Red/Grn
Alright, are you talking about the cluster now. Cause if you're talking underdash, Poison is going to know before me, so I have no cause to dispute. I'll be back to look after I sleep for two hours.
Yes I'm talking about the underdash harness. I'm not talking about the cluster. Your diagram at the top was for the cluster right?
suspendedHatch
Apr 26, 2006 07:16 AM
BOOSTWERKS
Oct 20, 2002 09:05 AM
