Integra Dash Q's!
Integra Dash Q's!
Yes, I know this topic has been beaten to death but I have a question that I couldn't answer while going through many threads on here. So here it is, Im going to be getting everything from a 2000 GSR. This is going to go into my EG. What I was wondering is, is there going to be any problems if I use the teg harness since its is OBD2? Also will the cluster work properly or am I going to have to get an older one? Thanks
Re: Integra Dash Q's! (Bizarre)
the cluster will work if u calibrate it...and i think the harness should be okay...but hey its not really that hard to convert your old one
hope this helps
hope this helps
im pretty sure all the wiring is the same. I put a 96 dash in my 98 without any problems. Just make sure you get a harness out of a 94-97 teg ( i think thats right) that should be just plug and play. mine wasnt
YES its possible. I dont know what all the calibration **** dude is talkin about is. I connected all the wires and mine worked. You shouldnt have a problem with it being obd2 is all i was sayin. To help yourself out i would pick up a underdash wiring harness so you can just repin and plug it in. let me know how it goes.
Re: Integra Dash Q's! (hndakd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndakd »</TD></TR><TR><TD CLASS="quote">YES its possible. I dont know what all the calibration **** dude is talkin about is. I connected all the wires and mine worked. You shouldnt have a problem with it being obd2 is all i was sayin. To help yourself out i would pick up a underdash wiring harness so you can just repin and plug it in. let me know how it goes.</TD></TR></TABLE>
by calibratin i meant makin sure that the speedo and tach are showin u what ur really goin...it normally should be fine, but mph may get messed up w/ diff rim sizes etc
Re: Integra Dash Q's! (ls_teg)
only problem you will have is the turn signals not working(blinkers) but search and you will find your answer on that.
Re: Integra Dash Q's! (R33CIVIC)
i used my stock vici dash harness..... i cut the civic cluster plugs off and wired in teh integra cluster plugs, i cut off the civic clock plug and wired in teh integra plug, i cut off the civic hazzard plug and wired in the integra plug and the same for the dimmer switch. teh defroster i didnt do it has 1 too many wires lol. the ac/ heater controls plugs will plug right into the ingegra controls no problems and the radio will plug right up too they are the same plugs. hope that helps
litterbox
13
02-12-2005 06:05 AM
AIWFCIATR
09-24-2004 12:37 AM
