ITR is having trouble starting, please help
Old Feb 11, 2005 | 09:40 PM
TypeRPaul's Avatar
Default ITR is having trouble starting, please help
Well the problem is intemitten and a pain in my ***! Sometimes when i start the car it wonk kick over so I press the pedal and then it roars to life but when i release it it dies. If i keep the RPM up until i drive for maybe 10-20 seconds it idles fine.
Problem two(might be related) when I am driving at a higher rpm in any gear( above 4500) and floor the gas the car sputters for a second and then begins accelerating.
Where should I start? my guess us to look at the injectors because they are at 100%dutie cycle and might be failing? I didn't have this problem after I had my hondata tuned it was great after that this has devloped recently
any ideas or things to check would be great, im on a p28 ecu with hondata and arent getting any cones but who knows wtf...please help
Old Feb 13, 2005 | 12:28 PM
TypeRPaul's Avatar
Default Re: ITR is having trouble starting, please help (TypeRPaul)
any ideas?
Old Feb 13, 2005 | 03:33 PM
yellow blur's Avatar
Check your plugs.
Old Feb 13, 2005 | 03:50 PM
uNF$@#!'s Avatar
Default Re: ITR is having trouble starting, please help (yellow blur)
or...you could search for some advice. but then again, when people post topics with useless thread titles, its somewhat hard to search, isnt it?
Old Feb 13, 2005 | 06:40 PM
white rocket's Avatar
I had a starting problem as well. I just turn the key to 'ON' without starting it and let the fuel pump prime the system(let it sit until the beeping stops), then start it up.
As for the sputtering; check the plugs and wires. I had my Spoon wires arcing onto my J's intake which is just fucked but I went back to stock and have had no problems. Good luck!!
Old Feb 13, 2005 | 06:47 PM
hYpE-R-29's Avatar
I HAD THE SAME PROBLEM....heres the trick......i ran a hondata with a p28 ecu.....the problem is the the connecter near the fuel filter..I FORGOT THE NAME..sorry ....just unplug it and presto the problem is gone...the p28 doesn't search for that thing..i think its the ECV plug
sorry i dont have the R anymore, but if u take a pic and post it..i can recognize it asap...but the problem will go away
good luck
Old Feb 13, 2005 | 06:54 PM
cjames235's Avatar
Default Re: ITR is having trouble starting, please help (hYpE-R-29)
^^^^^^ this guy is right i had to show someone the same thing before so i have a pic for you!
see its unplugged...... if you already have it unplugged then i dont know what to tell you but this sounds exactly like what your issue is
--chris
Old Feb 13, 2005 | 07:19 PM
RTW DC2R's Avatar
if you have hondata, was your startup enrichment, idle, or coolant temp tables changed? i had a similar problem when I was running my AEM EMSand it took awhile to dial that in. once the car warmed up it idled fine if I resarted it. Im not sure if these parameters are available with the hondata S100 but i would assume they are. otherwise it could be EVAP oe a vacuum problem.
Old Feb 13, 2005 | 07:32 PM
hYpE-R-29's Avatar
Default Re: ITR is having trouble starting, please help (cjames235)
thanks Chris for the pic...
TurboSedan
Dec 23, 2004 05:18 AM
messy hatch
Dec 21, 2004 05:51 PM
kaj
Apr 29, 2004 08:46 PM
Type RS
Apr 26, 2004 03:45 PM
GruvyTune
Apr 22, 2002 04:02 AM
