JR supercharger-need advice
wife just recently bought me a jackson racing supercharger, need advice on the install and extras to make in perform better. I have a 2000 civic dx. New to the game anything would help tremendously. thanks.
The install should be pretty straightforward if your competent with regular tools. Keep in mind though, the install probably will not take you 6-8 hours (as Jackson claims) unless you rush like you life depends on it. Put aside an entire weekend....even more. Little things will come up, get stuck, and break. You'll make a few runs to Pep Boys and Home Depot.
For safety and reliability these are some things to get:
-JR MAP Converter
Allows you to run less fuel pressure, advance the timing closer to stock, smoother transition from vacuum to boost, should eliminate any tip-in detonation.
-Boost, air-fuel, and fuel pressure guages.
Very good to have to make sure things are working properly and allows you to be proactive in the event something is not.
-Colder spark plugs
Helps to prevent detonation.
-Lower Temp Thermostat
Engine runs cooler, helps prevent detonation.
These are the basics for a safe, inexpensive set-up. There are many, many other routes to take to ensure engine longevity and maximum performance, but at a much higher price. E-mail me if you have more questions. As you can see below I have a SC'd SOHC too.
-JR MAP Converter
-Colder spark plugs
