CODE 15!!
ok here is the deal i put a b16 in my civic and it was running great and one day i was taking it for a spin and it started acting like it ran out of gas. but that was impossible because i have a half of tank of 93 in it. so when it finally broke down on me at my drive way, i rolled it in and did the codes got a code 15 (ignition output) so i changed the coil, nothing, changed the ignitor, nothing so i replaced the whole dizzy and still nothing. the car wants to start but it is not firing up it bogs for a second and nothing. what can i look for since i changed the whole dizzy? please let me know thanks guys!
btw
i got 220 compression
took the injectors out but left them in the fuel rail and had a nice spray show
new spark plug cables
new dizzy
new plug pre-gapped(checked and the gap is right)
battery is fully charged (battery tender every night)
tried it with to ecus stock and a chipped p28
btw
new dizzy
http://www.honda.co.uk/owner/C...2.pdf
here this seems to work for me all the time
since you replaced your dizzy (new icm) and tried different ecus I would say you got a slight short somewhere, in ignitor circuit.
ok that was a good article i have to try that out tomorrow, but the only reason why i don't know if that is the problem is because the dizzy is brand new and i tried it on two ecus i am going to try a different one tomorrow and see what happens
pm sent<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">do a search... I know there are a few topics on this as I just searched and got about 20 results.</TD></TR></TABLE>y cant people just answer the quetion. i mean if your not going to be of any help y rely.
try cleaning your injectors... that might be the problem...
i had the same problem in my car, if the injectors are dirty then there is little if no gas getting to your engine
nah it is not a gas problem i took the injectors out and left them in the rail, and they sprayed just nice the code 15 has something to do with the dizzy!
NOT GOING TO BELIEVE WHAT FIXED MY CIVIC.....THE F$%KING SPARK PLUGS
omg you don't know what we went thur and all this time it was my spark plugs, the reason why i ruled them out is because they done' even have 100 miles on them. but the car starts good now and runs well thanks for all the help peoples
DC5ftmfw
Mar 30, 2007 03:51 AM
