HEEEEEEEEEEELLP !! radius rod wont blot on to lca (can only get one blot in)
Old Feb 11, 2005 | 04:13 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default HEEEEEEEEEEELLP !! radius rod wont blot on to lca (can only get one blot in)
i am putting on a new lca and a new radius rod.
but i can only get one blot on them
pls. help i have been tring for an hour and 30 min this is all i need to drive my car after my wreak for the first on the year
Old Feb 11, 2005 | 04:18 PM
rasta420's Avatar
Default Re: HEEEEEEEEEEELLP !! radius rod wont blot on to lca (crxzcracer)
your crossmember may be bent. check that first, if you got into an accident.
take everything off of the LCA so you have some play in it, like the swaybar and fork. start the threads of one bolt, then try to move the LCA for the second bolt.
Old Feb 11, 2005 | 04:20 PM
crxzcracer's Avatar
Default Re: HEEEEEEEEEEELLP !! radius rod wont blot on to lca (rasta420)
but then it wont go in to the x member so it may be bent but the accident wasnt that bad
Old Feb 11, 2005 | 05:51 PM
crxzcracer's Avatar
ttt any one else have this prop
Old Feb 11, 2005 | 06:07 PM
HatchBox's Avatar
Skoobie no more...
jack the lca up with a jack. then try
Old Feb 13, 2005 | 08:15 AM
crxzcracer's Avatar
Default Re: HEEEEEEEEEEELLP !! radius rod wont blot on to lca (HatchBox)
well i jacked her up and it didn't really help to much.
it so close the holes are just off to where i can stick a screw driver in but not the bolt. but it wont move
i don't think that my whole crossmember is bent i think it is just the part where the lca bolts in to it. any ideas
Old Feb 13, 2005 | 09:04 AM
HatchBox's Avatar
Skoobie no more...
try loosing in the bolt that holds the radius rod in. 17mm i beleive its in the crossmemeber, maybe that will give you a little play in the radius rod to move it
Old Feb 13, 2005 | 01:26 PM
crxzcracer's Avatar
tried that.
and i have taken the lca out and then bolted up the rod but then i cant get the lca back in
Old Feb 13, 2005 | 06:26 PM
Reservation-Sensation's Avatar
i had the same problem i think u just have work with it, its a bitch.
Old Feb 13, 2005 | 08:06 PM
crxzcracer's Avatar
Default Re: (Reservation-Sensation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reservation-Sensation &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem i think u just have work with it, its a bitch.</TD></TR></TABLE>
any tip you could give me would be greatly appreciated
Old Feb 13, 2005 | 08:10 PM
ssl2k's Avatar
get a hammer
if that doesn't work, get a bigger ****** hammer.
Old Feb 15, 2005 | 01:03 PM
crxzcracer's Avatar
Default Re: (ssl2k)
and what should i do with this hammer cuz i got some big ones
ill take a picture to night to show how it is off, cuz the holes are almost off like a figure 8 but the holes overlap so you can put a screw drive in them
Old Feb 15, 2005 | 03:04 PM
4drEF's Avatar
Keyboard Humorist
I had that problem... couldn only get one of the bolts in.
Try this -
Remove the nuts from that hold the radius rods to the front crossmember.
Loosen all the front crossmember bolts so you can wiggle it around a little.
(Maybe even just have 2 bolts holding it in - one on each side.)
Then bolt down the radius rods to the LCA's.
Old Feb 15, 2005 | 04:44 PM
Default Re: (crxzcracer)
i got the other bolt in by putting a jack underneath the hub and did a lot of bitchen and moanin, pushin and pullin, thats about it finally i got it. i don't know if that helps but good luck.
thundernoodle
Jul 10, 2010 03:54 PM
IAcivicEK
Jul 1, 2007 07:37 PM
flip b18b
Jun 28, 2004 10:31 PM
KURRRRWA
Feb 6, 2003 10:29 PM
b18bvudoo
Aug 15, 2001 10:01 PM
