Slow Crank.
Old Feb 11, 2005 | 02:17 PM
HatchBox's Avatar
Skoobie no more...
Default Slow Crank.
Well i recently put my battery in the trunk.
I used 4 Guage wire and ran two 6 inch long 4 guage wires as grounds off the battery.
(I was told to use double the size of the power as the ground so thats why i ran 2 4 guages) I scrapped the body so its metal on metal for the grounds
I ran the positive wire down the passanger side and into the engine compartment where it runs into a junction box there i have the stock wires going to the starter and fuse box.
Is the 4 Guage wire not big enough or is my problem in the juction box?
Old Feb 11, 2005 | 02:19 PM
civicguy's Avatar
Default Re: Slow Crank. (HatchBox)
try 0 gauge
untitled's Avatar
Default Re: Slow Crank. (civicguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy &raquo;</TD></TR><TR><TD CLASS="quote">try 0 gauge</TD></TR></TABLE>
Old Feb 11, 2005 | 02:20 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Slow Crank. (untitled)
god damn why cant i have hook up in audio stores
So you all think thats the problem? too much resistance.
Makes sense.
Old Feb 11, 2005 | 02:22 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">god damn why cant i have hook up in audio stores
Makes sense. </TD></TR></TABLE>
positive.
Flood protection is enabled on this site. You are only allowed to post every 30 seconds. Try again in 2 seconds.
» Go Back
Old Feb 11, 2005 | 02:23 PM
HatchBox's Avatar
Skoobie no more...
ilove
HatchBox's Avatar
Skoobie no more...
having no flood
HatchBox's Avatar
Skoobie no more...
protection
ssl2k's Avatar
Put a few more grounds onto the motor also, the ground for the spark/starter needs to travel further...you want to get it off the engine as fast as possible
Old Feb 11, 2005 | 02:24 PM
untitled's Avatar
wtf.... hows come i flood.. I hate you
Old Feb 11, 2005 | 02:30 PM
HatchBox's Avatar
Skoobie no more...
haha,
Old Feb 11, 2005 | 02:45 PM
4drEF's Avatar
Keyboard Humorist
Try 2 gauge. That's what comes with the battery relocation kits.
I have a 4 door sedan with 2 gauge - starts every time without any problems.
You can run two 4 gauge wires if you don't have access to 2 gauge.
0 gauge is over doing it IMO.
Old Feb 11, 2005 | 02:48 PM
biggdogg's Avatar
Default Re: Slow Crank. (4drEF)
bad ground.
Old Feb 11, 2005 | 02:53 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Slow Crank. (biggdogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg &raquo;</TD></TR><TR><TD CLASS="quote">bad ground.</TD></TR></TABLE>
care to elaborate?
I have all grounds hooked up....
Old Feb 11, 2005 | 03:05 PM
4drEF's Avatar
Keyboard Humorist
Somebody already addressed that issue.
You 'should' ground the battery to the chassis as close to the battery.
It's also a good idea to run a couple more grounds - like one from the battery up to the engine compartment and another to somplace near the firewall or something.
This was also mentioned in about 2 weeks ago in a post about relocating batteries. The idea was that our cars don't have a full frame so there is really no serious connection between the back half and the fron half. By running the extra ground wire(s) you make a good connection to the battery.
Anyway, I don't have any spare ground wiring. I plan to do it just for fun... maybe my headlights will be brighter?!?!? I don't have any starting problems or alternator whine over the radio so I think I'm good to go.
Old Feb 11, 2005 | 03:10 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Somebody already addressed that issue.
Anyway, I don't have any spare ground wiring. I plan to do it just for fun... maybe my headlights will be brighter?!?!? I don't have any starting problems or alternator whine over the radio so I think I'm good to go.</TD></TR></TABLE>
Good info, i have a bunch of 4 guage wire left over.
I redid the tranny and valve cover grounds with 4 guage.
So i should run one off my intake manifold to firewall.
Maybe i will ran a ground to the block as well?
Old Feb 11, 2005 | 03:16 PM
4drEF's Avatar
Keyboard Humorist
The tranny-to-chassis wire is the 'big' one. It has a direct connection to the starter.
If you have extra cable, maybe consider running it from the negative battery terminal and connect it up to the tranny-to-chassis cable.
Old Feb 12, 2005 | 10:19 AM
biggdogg's Avatar
and always dremel or sand the paint off so to have a metal to metal contact
Old Feb 12, 2005 | 10:29 AM
untitled's Avatar
Kinda off topic but one time i went to do a swap on a car (house call ) and the kid had ran the ground all the way back up the the front of the car.
I kinda laughed but i wasnt too hard on him, he tried.
notmightydx
Engine Management and Tuning
Oct 21, 2008 08:00 AM
oc_civic
Apr 27, 2007 10:06 AM
greenEFSI
18
Dec 22, 2006 07:15 PM
lsvtecrocket
28
Jan 8, 2004 09:28 PM
