clutch alignment tool...needed??
Old Feb 11, 2005 | 12:05 PM
RTW DC2R's Avatar
Default clutch alignment tool...needed??
well i need to install my clutch and dont have an alignment tool. can i do it without or do i risk screwing something up.
Old Feb 11, 2005 | 12:12 PM
Dan GSR's Avatar
Default Re: clutch alignment tool...needed?? (RTW Ryan)
makes it easier to get the transmission back on
without it, the clutch disc, may not be centered
Old Feb 11, 2005 | 12:25 PM
Bbasso's Avatar
I got one f00l!
It's free t00
Old Feb 11, 2005 | 12:32 PM
RTW DC2R's Avatar
grrrrrrrrrrrrr
Old Feb 11, 2005 | 12:35 PM
92TypeR's Avatar
FSAE
Default Re: (RTW Ryan)
Any local ricer shop will have a bunch laying around. Call and see if you can get one.
Otherwise, I'm sure someone has one laying around that is willing to send one to you. They come with almost every clutch kit I've seen.
Old Feb 11, 2005 | 02:51 PM
KayOs's Avatar
Use a broom stick handle and a little bit of eye coordination to center the clutch disk. Works like a charm
I also have a plastic clutch alignment tool if you need it.
Old Feb 11, 2005 | 03:07 PM
sackdz's Avatar
Default Re: clutch alignment tool...needed?? (KayOs)
Just switched a clutch wihtout one yesterday... make the bolts on the PP finger loose so you can just barely slide the clutch around... get it centered the best you can then put the tranny up and it will center once the mainshaft hits the pilot bearing. pull it straight back off and tighten the PP then it will go right on.
Old Feb 11, 2005 | 04:37 PM
Dropspeed's Avatar
Default Re: clutch alignment tool...needed?? (sackdz)
Or use a socket on and extension........................if slight size adjustment is needed, a little electical tape works.
Mattj.
tacchan
26
Mar 17, 2010 11:25 AM
wkrpfm
Acura TL, RL & ZDX
Dec 3, 2004 09:35 AM
fastlude69
Jul 14, 2004 07:12 PM
MachAF
Mar 14, 2003 03:46 PM
Black R
May 2, 2002 10:23 AM
