My Timing Off?
Old Feb 11, 2005 | 11:31 AM
1SlowSi's Avatar
Default My Timing Off?
Last my and friend changed out the timing belt. Mostly him though. Everything was dead on. I just attempted to start it and it sounded like crap.
**got a new basemap because i just put a turbo on it too.**
I heard something in the timing belt cover like **** was flyin around in there. So i took off the valve cover and that, and looked at the cam gears. The two dots were both pointing at 10 o'clock. I thought that they were supposed to be opposite. Could this be why it sounded like ****? I think the belt was jumping time and that was the noise i was hearing. Could i have bent a valve? it only ran for like 10 seconds.
Old Feb 11, 2005 | 11:35 AM
DaMmniTz's Avatar
Default Re: My Timing Off? (1SlowSi)
hey i think i have the same problem as you. It's after i swapped a motor in. Can u check my video and see if it sounds like yours?
http://home.ripway.com/2005-2/...5.MOV
Old Feb 11, 2005 | 11:38 AM
1SlowSi's Avatar
Default Re: My Timing Off? (DaMmniTz)
Also... i have a B16A2... im using CTR cams with cam gears that were used in a GSR head (made for a GSR). Is this a problem?
Old Feb 11, 2005 | 11:41 AM
1SlowSi's Avatar
Very similar sound but mine was MUCH worse. Like i said, it sounded like **** flying around behind that timing belt cover. Without that then yes. Same thing i guess.
Old Feb 11, 2005 | 12:59 PM
1SlowSi's Avatar
i think i may have figured out the noise from the timing belt cover. Right below the cam gears there a piece of the lower timing belt cover that goes around it. Its rubbing agaist the inside of the cam gear. Hopefully that stops the noise. Idle still sucks *** though.
b16-ef-si
May 16, 2009 03:23 PM
PandaBear
Feb 24, 2006 10:00 PM
RacerZook
Jan 6, 2004 12:54 AM
RacerZook
Jan 5, 2004 07:36 PM
oryanh
Jul 8, 2002 10:33 AM
