Vtec plug for 96 EX harness
Old Feb 11, 2005 | 08:26 AM
endlessdv's Avatar
Default Vtec plug for 96 EX harness
I just got my 96 EX harness for my 1st gen b16 going into a 98 DX. I have a few questions. The vtec plug on the harness is green/yellow and same as the plug wire on the vtec soleniod. But they are different plugs. Do I cut the plugs and solder the wires together or what?... Also there are a few plugs(about 3-4) that arent plugged in because I cant find anything for em. Does this usually happen?
Old Feb 11, 2005 | 08:31 AM
EE_Chris's Avatar
Default Re: Vtec plug for 96 EX harness (endlessdv)
Yes, you can cut off the connectors and solder the wires together - however, this leaves you with no way to disconnect it aside from cutting and soldering again.
Yes there are going to be plugs left over - you have an OBD2 harness and an OBD1 engine. One plug is going to be for the CKF sensor as OBD1 knows nothing about it.
You should buy/download a Helms for your car and donor engine/ECU.
Old Feb 11, 2005 | 08:32 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endlessdv &raquo;</TD></TR><TR><TD CLASS="quote">I just got my 96 EX harness for my 1st gen b16 going into a 98 DX. I have a few questions. The vtec plug on the harness is green/yellow and same as the plug wire on the vtec soleniod. But they are different plugs. Do I cut the plugs and solder the wires together or what?... Also there are a few plugs(about 3-4) that arent plugged in because I cant find anything for em. Does this usually happen?</TD></TR></TABLE>
obd0 and obd2 vtec solenoid plugs are different, so you'll need to solder on a new connector. i wouldn't solder the 2 together as you might need to dissconect it later. obd2 cars have a few more sensors (crank fluctuation etc) that obd0 motors don't have.
bungdogjb
Dec 8, 2015 05:27 AM
boostedekhatch
Oct 2, 2008 05:48 PM
BlKdOutEk
Sep 16, 2005 09:00 PM
awdriscol4
Jan 24, 2005 07:09 PM
94_civicEx
May 14, 2004 06:11 AM
