wich distributor and ecu
Old Feb 11, 2005 | 07:21 AM
sloweredcivic's Avatar
Default wich distributor and ecu
i am going to put in a b16a2 in my hatch and i paln to convert to obd1 or how hard is it to go to obd 2 but any way i nned to know wich distributor and what ecu will work with that engine when being used as obd1
Old Feb 11, 2005 | 07:24 AM
EP3_05's Avatar
Default Re: wich distributor and ecu (sloweredcivic)
Any OBD1 B series distributor will work.
It is your choice on ecu. You can run a P30 ecu or a chipped P28.
Old Feb 11, 2005 | 07:25 AM
pwrofdrm's Avatar
If you want OBD-1 you need a distributor, injectors, and ecu from either a 92-95 Civic SIR2 from Japan or from a Del Sol VTEC. You're also going to need a conversion harness. I bought mine from blown90hatch
Old Feb 11, 2005 | 11:16 AM
would you want to buy a used distibutor or one from distibutor king for like 199
Old Feb 11, 2005 | 11:24 AM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">i am going to put in a b16a2 in my hatch and i paln to convert to obd1 or how hard is it to go to obd 2 but any way i nned to know wich distributor and what ecu will work with that engine when being used as obd1</TD></TR></TABLE>
Any B-VTEC distributor will work, OND1 or OBD2, depending on the connector you use, repin the distributor to use the connector on your harness, or visa versa. Yonaka has a good thing going with aftermarket distributors, 3 year warrenty, just watch out for shipping charges.
As far as ECUs, depending on if you know how to chip, etc, you can use a very wide variety of ECU's, I would say, get a P28 (chipped) or P30 for your app.
Old Feb 11, 2005 | 09:10 PM
Default Re: wich distributor and ecu (Bunger)
do you mean that you can use an obd2 dizzy on an obd1 application by changing the wiring around? and i have done some searching and will a ls work if you cut and ear off of it??? if so how to?
7rrivera7
May 14, 2014 03:25 AM
fin781
Jan 19, 2007 09:16 PM
89hatcher
Jun 5, 2006 02:01 AM
Adam West
May 8, 2006 03:47 AM
racingant
Jun 8, 2004 07:37 AM
