99 civic wont start at all???help
Old Feb 11, 2005 | 12:50 AM
jdmcivic1999's Avatar
Default 99 civic wont start at all???help
my friends and i replaced my head gasket and some other ones and now my car wont start at all. it wont click over, we re-did the timing and everything else, it just wont start up, we've tried everything and dont know what else to try. any ideas???
Old Feb 11, 2005 | 12:53 AM
hatchi's Avatar
Default Re: 99 civic wont start at all???help (jdmcivic1999)
check the wire going to starter and all grounds
Old Feb 11, 2005 | 01:22 AM
rasinhell's Avatar
make sure the battery is hooked up right
Old Feb 11, 2005 | 10:58 AM
pornstarSR's Avatar
does it turn over? or turn over and not start?
Old Feb 11, 2005 | 12:14 PM
Default Re: 99 civic wont start at all???help (pornstarSR)
i got it to start once, but than it shut off, and now when i try to start it, it sounds like wants to start but doesnt. it sounds like its winding up??? we tried to jump start it and that didnt do anything
Old Feb 11, 2005 | 12:42 PM
alotawatts's Avatar
How long did it run before the problem started ...or maybe I should ask how did you time it if it won't start ?
Old Feb 11, 2005 | 12:54 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: 99 civic wont start at all???help (alotawatts)
So you got it to start then it turned back off immediately?
Old Feb 11, 2005 | 01:28 PM
Default Re: 99 civic wont start at all???help (BrokeAssPinoy)
ok i finally got it to start running again, i took out the 450cc injectors and the resistor pack and put gsr injectors in and had to jump start my car and now its running. thanks for ur guys help
Sutterlude
Apr 4, 2009 09:19 PM
Tunerstop
Jun 12, 2008 10:03 AM
PHiZ
Jul 5, 2004 05:21 PM
