99 si dash in 97 cx with 96-98 ex cabin harness
Old Feb 10, 2005 | 09:38 PM
redboost10's Avatar
Default 99 si dash in 97 cx with 96-98 ex cabin harness
my 97 cx has a 96-98 ex cabin and engine harness, is the 99 si dash plug and play?
Old Feb 10, 2005 | 09:59 PM
redboost10's Avatar
Default Re: 99 si dash in 97 cx with 96-98 ex cabin harness (tgh99si)
ive searched
Old Feb 10, 2005 | 10:08 PM
redboost10's Avatar
also will the 96-98 ex 5 spd cabin harness work in the 97 cx hatch, like will it hook up to everything?
Old Feb 11, 2005 | 01:02 AM
hatchi's Avatar
you will need to do some wiring if you decide to use 99-00 climate control.
Old Feb 11, 2005 | 02:42 AM
Unjockable's Avatar
New User
Default Re: 99 si dash in 97 cx with 96-98 ex cabin harness (hatchi)
what exactly are you trying to do? if you're doing the climate control conversion, you DON'T need the 99-00 dash harness. you'll need the climate control harness (and other little **** like the tubes, hoses, etc...). that's it. all plug and play. no wiring needed. trust me, i've done it. unlike most people, i'm speaking of experience.
i bet someone's gonna tell me i'm wrong....
Old Feb 11, 2005 | 02:49 AM
endlessdv's Avatar
Default Re: 99 si dash in 97 cx with 96-98 ex cabin harness (Unjockable)
Could you use a automatic EX harness on a DX 5 speed with b16?
Old Feb 11, 2005 | 04:20 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable &raquo;</TD></TR><TR><TD CLASS="quote">
i bet someone's gonna tell me i'm wrong....</TD></TR></TABLE>
you're wrong!!! fool
Old Feb 11, 2005 | 05:27 AM
monicle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable &raquo;</TD></TR><TR><TD CLASS="quote">what exactly are you trying to do? if you're doing the climate control conversion, you DON'T need the 99-00 dash harness. you'll need the climate control harness (and other little **** like the tubes, hoses, etc...). that's it. all plug and play. no wiring needed. trust me, i've done it. unlike most people, i'm speaking of experience.
actually you are wrong and Im talking from experience also you will need to do wiring if you want your rear defroster to work. sure its only 1 wire but it still counts . for some step by step instructions here is my install.
http://repo.jackmoves.com/album228
Old Feb 11, 2005 | 05:47 AM
redboost10's Avatar
Default Re: 99 si dash in 97 cx with 96-98 ex cabin harness (monicle)
im trying to put a si gauge cluster in my 97 cx using a 96-98 ex cabin harness
Old Feb 11, 2005 | 05:50 AM
monicle's Avatar
yeah that wont matter. the cx cabin harness would have worked but it doesnt matter. the si cluster will plug right in.
Old Feb 11, 2005 | 06:04 AM
redboost10's Avatar
my cx cabin and engine harness is all cut to ****. so if i get a 96-98 ex 5 spd cabin and engine harness and i already have the 97 cx, 99 gauge cluster, and a 99 built b16a2, i should have no problems wiring all this up, right?
Old Feb 11, 2005 | 06:22 AM
monicle's Avatar
well it depends. a minute agou I thought you were wanting to convert the entire dash. are you just wanting to put a si gauge cluster in there and stick with your current dash?
Old Feb 11, 2005 | 06:25 AM
redboost10's Avatar
i meant gauge cluster, not dash, i wanna put the si gauge cluster in my 97 cx using a 96-98 ex cabin harness.
Old Feb 11, 2005 | 06:42 AM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">i meant gauge cluster, not dash, i wanna put the si gauge cluster in my 97 cx using a 96-98 ex cabin harness.</TD></TR></TABLE>
The cluster should be plug 'n play
This is the best write up on a dash or climate control swap I've seen on here though:
https://honda-tech.com/zerothread?id=605432
Old Feb 11, 2005 | 06:54 AM
monicle's Avatar
Default Re: 99 si dash in 97 cx with 96-98 ex cabin harness (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=605432</TD></TR></TABLE>
did you see mine?
its a real step by step not just the cliffs notes. My hats off to chameleon though for breaking some ground.
Old Feb 11, 2005 | 08:45 AM
redboost10's Avatar
thanks guys, yeah its the 99 si gauge cluster in a 97 cx with 96-98 ex dash harness swap im refering too. those write ups are very helpful. thank you
Old Feb 11, 2005 | 11:52 AM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">
did you see mine?
its a real step by step not just the cliffs notes. My hats off to chameleon though for breaking some ground.</TD></TR></TABLE>
Detailed as hell... u should post it in the thread I put the link to to kill any and all future questions... good stuff man!!!
b18bEKcoupe
Jan 16, 2008 02:04 PM
E.46
Apr 15, 2006 11:41 PM
nahmanitscool
20
Mar 23, 2005 01:14 PM
pootie.teng
Feb 12, 2004 01:16 AM
fowler!
32
Aug 26, 2003 05:37 PM
