constant speed problem
Old Feb 10, 2005 | 05:55 PM
mar778c's Avatar
Community Builder
Community Influencer
Default constant speed problem
Guys, my car has problem holding constant speed if the rpms are below 3900. I've got a 90 STD hatch with a 1st gen b16a.
Here are some of the things I've tried:
(1a) search function on HT
then on the car
(1) adjust TPS to .45 volt at idle,
(2) check harness for shorted connections
(3) check the intake manifold and throttle body for vaccuum leaks
(4) check ignition timing, set at stock.
(5) new dizzy rotor and cap from acura dealer
(6) check all vacuum connections for leaks
Any help would be appreciated:
vedha
Oct 9, 2009 09:46 PM
vtNaMeSe
Jun 21, 2003 06:55 AM
