Oil For Engine
Old Feb 10, 2005 | 05:42 PM
old_school_dohcvtec's Avatar
Default Oil For Engine
After reading many post about mobil synthetic oil, i want to use it but a friend told me that if my engine is use to non synthetic oil then i cant switch to synthetic. Is that true? My My car has 130k and has been using non synthetic oil all its life.
Old Feb 10, 2005 | 06:00 PM
DarkDragon's Avatar
Default Re: Oil For Engine (old_school_dohcvtec)
if u havent been running synthetic and u switch it could actully cause problems since synthetics and non-synthetics dont mix, even though there will only be a little left after u drain ur oil its in the small places where oil is vital the most and if the oils wont mix then it could cause problems
Old Feb 10, 2005 | 06:03 PM
Sack Master's Avatar
Default Re: Oil For Engine (DarkDragon)
The oil companys say you can mix synthetic with non(thats what a synthetic blend is). They do state that you should always use the same brand though. As for a car that has been using regular oil for a lot of miles. It has shown that changing to synthetic in some cases caused oil leaks.
deerman2701
14
Jan 11, 2012 07:58 AM
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
92EG8
Nov 1, 2006 06:53 PM
blkboyan
Oct 30, 2006 09:02 AM
TypeR01-424
Aug 17, 2001 07:51 AM
