Radiator fan isn't spinning.
Old Feb 10, 2005 | 04:46 PM
rasinhell's Avatar
Default Radiator fan isn't spinning.
Sup guys. I don't know if my car is having a problem or if this is normal. I let the car idle for like 20 minutes and i'm revving the engine every few minutes because i'm using some throttle body cleaner. Anyway I noticed that the radiator fan wasn't even spinning.
I can't tell my car temp because the temp gauge is broken on my cluster. Does anyone know when the fan is supposed to start spinning?
Old Feb 10, 2005 | 04:47 PM
ABK's Avatar
ABK
Default Re: Radiator fan isn't spinning. (The-Beast)
is it cold where you live???
get the temp gauge fixed first, seriously....
Old Feb 10, 2005 | 04:48 PM
rhdSiR's Avatar
good question man...my goddamn cooling fan never goes on too...never once have i seen it running...my car doesnt overheat or anything, even if i let it idle the cooling fan will not go on....im thinking maybe the relay is bad
Old Feb 10, 2005 | 04:53 PM
rasinhell's Avatar
Default Re: Radiator fan isn't spinning. (rhdSiR)
Yeah, fortunately I dont drive this car around. It's a garaged project car that I dont plan to drive around until summer. I'll get that gauge asap... But just wondering, Could it possibly be the thermostat thingy? Do u know what i'm talking about? the little metal piece on the block that has all the tubes that connect to it?
Oh yeah and its not too cold where I live. probably like 55
Old Feb 10, 2005 | 04:56 PM
rhdSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast &raquo;</TD></TR><TR><TD CLASS="quote">Could it possibly be the thermostat thingy? </TD></TR></TABLE>
bad thermo if stuck open will cause over cooling, if stuck closed will cause the car to overheat...
Old Feb 10, 2005 | 04:58 PM
rasinhell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdSiR &raquo;</TD></TR><TR><TD CLASS="quote">bad thermo if stuck open will cause over cooling, if stuck closed will cause the car to overheat...</TD></TR></TABLE>
So even if it were stuck closed, the radiator fan would still work right? I'm just wondering if maybe the thermostat, if broken, would throw off the temp and make the fan not run when it should be running. =P jw.
Old Feb 10, 2005 | 05:03 PM
DaZman69's Avatar
your fan runs off the coolant temp sensor
your cool temp gauge isnt getting a reading......
hmmmm lets see what could be the problem????
Old Feb 10, 2005 | 05:04 PM
rasinhell's Avatar
Default Re: (DaZman69)
where's that located? is that the plug that plugs into the radiator?
Old Feb 10, 2005 | 05:08 PM
DaZman69's Avatar
Default Re: (The-Beast)
should be right under the dizzy, u'll see two wires going to it
Old Feb 10, 2005 | 08:01 PM
rasinhell's Avatar
Does anyone else have any input on the subject?
Old Feb 10, 2005 | 08:10 PM
EK k kay's Avatar
Mine seems like it never comes on either, but it does come on on rare occasions and turns off quickly after. I'm up in Seattle and lately it's been 30-50 degrees F out so I'm guessing it's cold enough.
Old Feb 10, 2005 | 09:22 PM
rasinhell's Avatar
Default Re: (chowmien)
really? im in tacoma. by the way, does anyone else have any input on this?
Modified by The-Beast at 10:37 PM 2/10/2005
Old Feb 10, 2005 | 09:44 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast &raquo;</TD></TR><TR><TD CLASS="quote">really? im in tacoma. by the way, does anyone else have any input on this?
Modified by The-Beast at 10:37 PM 2/10/2005</TD></TR></TABLE>
Yep. This started about a month ago. I thought my fan was broken too.
Old Feb 10, 2005 | 11:44 PM
rasinhell's Avatar
Bump, still need help. Anyone have any ideas on how to diagnose the problem?
One thing to keep note of. I did notice a VERY SMALL AMOUNT of smoke coming from somewhere near the thermostat area. Not saying its coming from the thermostat but it was comign from that area.
thx
SFlCrx
12
Sep 25, 2006 06:24 PM
7808
Jan 2, 2006 11:47 PM
turbotime
Nov 14, 2005 12:45 PM
rasinhell
Feb 12, 2005 06:03 PM
