92 Accord Electrical problem
Recently I was driving down the road, when this car pulled out in front of me and came to a stop. I had to slam on the breaks and pull up the emergency break, The other car, nor mine was damaged, but I noticed after words my cigarette lighter, and CD player weren't getting power. I was wounding if anyone had any ideas why this might be?
I've checked and replaced all my fuses, I've taken the CD player out and checked all the wires, but I can't seem to get it working.
Suggestions?
Suggestions?
Pull your CD player, ashtray, etc out and inspect all the wires to make sure they did not get damaged. Also, check your connection on the back of the cigarette lighter and make sure your harness isn't loose on the back of your CD player. If your CD player is aftermarket, it may also have a fuse in the wiring harness.
It sounds like you have a problem in the wiring to me if all your fuses are good.
Good luck.
Good luck.
Well, I rewired all the wires on my wiring harness for my CD player, and changed all the fuses under the hood, as well as the fuse on the wiring harness for my cd player.
Nope, the security lighte on my CD player flashes when I remove the face, but when I turn the power on, ...nothing. The cigarette lighter, still nothing.
The common fuse for both the radio and cigarette lighter is fuse no. 11 in the kick panel fuse box. This is the last fuse in the top row of fuses. See below:
[ 7 ] [ 8 ] [ 9 ] [ ] [ 11 ]
[ 4 ] [ 5 ] [ 6 ]
[ 1 ] [ 2 ] [ 3 ]
Modified by cmrvi1 at 11:41 PM 2/10/2005
[ 4 ] [ 5 ] [ 6 ]
[ 1 ] [ 2 ] [ 3 ]
rat321z
Audio / Security / Video
Jul 26, 2007 04:38 AM
