92 Accord Electrical problem
Old 02-10-2005, 04:46 PM
Xilade's Avatar
Default 92 Accord Electrical problem
Recently I was driving down the road, when this car pulled out in front of me and came to a stop. I had to slam on the breaks and pull up the emergency break, The other car, nor mine was damaged, but I noticed after words my cigarette lighter, and CD player weren't getting power. I was wounding if anyone had any ideas why this might be?
I've checked and replaced all my fuses, I've taken the CD player out and checked all the wires, but I can't seem to get it working.
Suggestions?
Old 02-10-2005, 05:39 PM
blueaccord90's Avatar
Default Re: 92 Accord Electrical problem (Xilade)
Pull your CD player, ashtray, etc out and inspect all the wires to make sure they did not get damaged. Also, check your connection on the back of the cigarette lighter and make sure your harness isn't loose on the back of your CD player. If your CD player is aftermarket, it may also have a fuse in the wiring harness.
It sounds like you have a problem in the wiring to me if all your fuses are good.
Good luck.
Old 02-10-2005, 06:18 PM
Xilade's Avatar
Default Re: 92 Accord Electrical problem (blueaccord90)
Well, I rewired all the wires on my wiring harness for my CD player, and changed all the fuses under the hood, as well as the fuse on the wiring harness for my cd player.
Old 02-10-2005, 06:26 PM
It sounds like your CD player got F'd up. Did you get your cigarette lighter working?
Old 02-10-2005, 06:43 PM
Xilade's Avatar
Nope, the security lighte on my CD player flashes when I remove the face, but when I turn the power on, ...nothing. The cigarette lighter, still nothing.
Old 02-10-2005, 06:56 PM
Well, I don't know what to tell you then. Hopefully someone else can be of more help.
Old 02-10-2005, 07:00 PM
Xilade's Avatar
Appreciate it though
Old 02-10-2005, 07:29 PM
cmrvi1's Avatar
The common fuse for both the radio and cigarette lighter is fuse no. 11 in the kick panel fuse box. This is the last fuse in the top row of fuses. See below:
[ 7 ] [ 8 ] [ 9 ] [ ] [ 11 ]
[ 4 ] [ 5 ] [ 6 ]
[ 1 ] [ 2 ] [ 3 ]
Modified by cmrvi1 at 11:41 PM 2/10/2005
si_23
04-10-2011 01:56 PM
Triptweeze
17
03-02-2008 04:43 PM
mrmcnotbuff
02-17-2008 06:06 PM
methos713
Audio / Security / Video
01-15-2008 05:41 AM
Quick Reply: 92 Accord Electrical problem
