m2b4 transmission info
Old Feb 10, 2005 | 02:55 PM
18gLUDE's Avatar
Default m2b4 transmission info
this is the lsd tranny right? does it just directly replace a stock tranny? where can i find one? thanks
Old Feb 10, 2005 | 03:21 PM
CXHATCHver2.2's Avatar
Default Re: m2b4 transmission info (18gLUDE)
yes it is the lsd tranny, once in a while you find one around here, just search h22 tranny and sometimes theres one or 2 in there. it does replace the stock tranny but for some odd reason the housing had an xtra bolt hole on the very bottom when i swapped mine out. no big deal really, if it gets warmer i could take a picture for ya but i dont think it hurts anything, ive had it on there since aug and no problems whatsoever.
Old Feb 10, 2005 | 05:29 PM
18gLUDE's Avatar
Default Re: m2b4 transmission info (CXHATCHver2.2)
thanks. will my exedy clutch and flywheel work with this tranny as well?
Old Feb 10, 2005 | 06:01 PM
yes it will, i had an exedy clutch and fidanza flywheel at the time, worked fine
Old Feb 10, 2005 | 09:30 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gLUDE &raquo;</TD></TR><TR><TD CLASS="quote"> where can i find one? thanks</TD></TR></TABLE>
you could give steve a call at hmotorsonline,
he might be able to hook you up.
Old Feb 11, 2005 | 04:00 AM
KENLUDE97's Avatar
Default Re: m2b4 transmission info (SKDRCR)
Yea mine came from Hmotorsonline. I like it alot. But i think that if i could do it again i would buy a quaife for the car and keep the stock tranny.
Old Feb 11, 2005 | 07:46 AM
18gLUDE's Avatar
Default Re: m2b4 transmission info (KENLUDE97)
if i have the tranny out already is it hard to install the quaife lsd? or does it have to be installed by a professional?
Old Feb 13, 2005 | 10:00 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gLUDE &raquo;</TD></TR><TR><TD CLASS="quote">this is the lsd tranny right? does it just directly replace a stock tranny? where can i find one? thanks</TD></TR></TABLE>
For H22A in a Civic people, they have to get slightly shorter axles because the housing is a little wider.
Old Feb 13, 2005 | 10:56 AM
mgags7's Avatar
you will want a pro to install the quaife unless your mechanical ability surpasses your searching abilites.....
dont waste your money on the quaife, its a lot more money for not much more performance....
Old Feb 13, 2005 | 01:46 PM
Default Re: (mgags7)
i didnt have to get different axles when i switched the trannies, i have hasport axles if it helps ya out any
Old Feb 13, 2005 | 07:07 PM
cpforyou's Avatar
Default Re: (CXHATCHver2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHATCHver2.2 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt have to get different axles when i switched the trannies, i have hasport axles if it helps ya out any</TD></TR></TABLE>
When I switched I had to get a shorter passenger side axle.
Old Feb 13, 2005 | 09:44 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">you will want a pro to install the quaife unless your mechanical ability surpasses your searching abilites.....
dont waste your money on the quaife, its a lot more money for not much more performance....</TD></TR></TABLE>
not much more performance compared to what? a m2b4? or an open diff? the honda OEM helical is decent, but i'd rather have a quaife and a lifetime warranty. compared to an open diff there is no comparison.
if the tranny is loose, you should be able to find someone to install it for about $200 bucks. it's complicated in there but if the person knows what they're doing and has the right tools, it's not too time consuming. doing it yourself can be kind of intimidating. you have to preload and shim the diff correctly, and getting the ring gear off can be difficult.
DailyBlown
Mar 26, 2005 02:16 PM
kaimo
Feb 3, 2004 02:03 AM
Monkey Fing a Coconut
Dec 12, 2003 07:32 AM
yaoming
Mar 23, 2003 06:34 PM
flashgsr
Nov 1, 2002 03:19 AM
