Honda S2000 Honda S2000
Clunk! (rear end sounds)
Old Feb 10, 2005 | 02:23 PM
s2kds's Avatar
Default Clunk! (rear end sounds)
As you know i bought a s2000 rebuild project. (if not you know now) The left 1/2 shaft was missing when i got it and had probably been off for a year or two. I reinstalled every thing according the the Honda service manual.
So i went for my first ride in freezing cold Ohio today. (despite the problems it was awesome ) When i put it in gear and give it a very little go it clunks in the back and jumps a little. Any ideas?
Thanks.
Old Feb 10, 2005 | 02:41 PM
papa5murf's Avatar
Default Re: Clunk! (s2kds)
your rear diff might be going bad....
Old Feb 10, 2005 | 02:44 PM
revhi's Avatar
Its hard to be an internet mechanic from noise discriptions. Where are you in Ohio? Why dont you take it to a Honda dealer, if not to get fixed, at least for a propper diagnostics
Old Feb 10, 2005 | 04:22 PM
fknfast's Avatar
Default Re: (revhi)
if it clunking thats not good! what gear did you put in there! did you use gear oil for break in? the backlash and bearings ok? torque specs?
Old Feb 10, 2005 | 04:23 PM
s2kds's Avatar
Default Re: (revhi)
Well like i said it started today. I'm from western ohio in celina. lima would be the biggest town around.
Old Feb 11, 2005 | 07:24 PM
red9s's Avatar
Default Re: (s2kds)
It's official, mine went out today. so no more peeling out and stuff for a while. This sux. but looking to either clean it, or get a new one.
Old Feb 11, 2005 | 10:43 PM
fknfast's Avatar
Default Re: (Leg3ndary S)
what about an 04 rear end?
Old Feb 12, 2005 | 08:37 AM
papa5murf's Avatar
Default Re: (fknfast)
the 04 rear end is a little stronger i believe... but i'm not sure what they changed on it..
Old Feb 12, 2005 | 04:00 PM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
Default Re: (03s2kblue)
I had that sound and it was the rear drivers side axle nut.All I did was tighten the nut then the clunk sound went away.
01 S2000 silverstone/red
91 mr2 turbo
Old Feb 13, 2005 | 12:54 PM
CWESTINAP1's Avatar
Default Re: (Scarface928)
can you post up what size the nut is? and also the torque setting? thanks
Old Feb 13, 2005 | 01:09 PM
CWESTINAP1's Avatar
Default Re: (CWESTINDC2)
never mind its 36mm and 220 lbs.
Old Feb 13, 2005 | 02:24 PM
s2kds's Avatar
The spindle nut is 24 x 1.5
and tightened to 181 ft lbs
Old Feb 13, 2005 | 03:51 PM
CWESTINAP1's Avatar
Default Re: (s2kds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kds &raquo;</TD></TR><TR><TD CLASS="quote">The spindle nut is 24 x 1.5
and tightened to 181 ft lbs </TD></TR></TABLE>
Wrong. The spindle nut is also 36mm, and the honda manual was wrong. (honda misprint?)
Modified by CWESTINDC2 at 5:05 PM 2/13/2005
Old Feb 13, 2005 | 07:00 PM
s2kds's Avatar
I guess it was a misprint i got it straight from the service manual.
Old Feb 13, 2005 | 07:23 PM
YoshiS2K's Avatar
Hmm. On my FC I had the same issue, it sounds like. It would have a "thunk" feeling to it when I'd let off the gas, and even when I'd BARELY let on the gas. I had the rear diff mounts replaced, and even the rear diff pinion gear seal, since it was leaking... Still did it. Shop guy is like "Oh, it's yours struts! Tighten them up, they're adjustable, right?" WRONG.
On an older car, I'd suggest that the problem be the subframe bushings...but on that new of a car? I say it's your diff mounts.
Put the car on a lift, and shift it through the gears, if the diff goes up and down...lol, go from there.
Old Feb 13, 2005 | 07:30 PM
red9s's Avatar
Default Re: (YoshiS2K)
anyone got a price quote on how much it would take to clean it out?
Old Feb 13, 2005 | 07:39 PM
Nishant's Avatar
clean what out?
Old Feb 13, 2005 | 10:08 PM
Atheist's Avatar
Did you check to be sure the axles were in good shape? I would do that first, pop 'em out and see how freely they rotate.
Old Feb 20, 2005 | 08:12 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">the 04 rear end is a little stronger i believe... but i'm not sure what they changed on it..</TD></TR></TABLE>
as far as I could tell, the yoke flange, that's about it.
EJ8_Man
Honda CR-V & Element
Feb 10, 2016 05:44 PM
Redirwol1
Honda S2000
Jan 23, 2006 12:32 AM
KID808
Honda S2000
22
Sep 25, 2005 12:03 PM
ExtremePowerOuters
Honda S2000
May 24, 2005 02:46 PM
conesmasher
Mar 12, 2003 01:13 PM
