Honda S2000 Honda S2000
Explain typical rear end problems on S
Old Aug 23, 2005 | 07:57 PM
KID808's Avatar
New User
Default Explain typical rear end problems on S
What are the symptoms of a rear end going bad on a 00 S2000.
It there a noise a creak at preload?
Is this the PIG or the half shaft?
Any input would be great.
Or are they just noisy in the rear?
Old Aug 23, 2005 | 08:22 PM
s2kkk's Avatar
Default Re: Explain typical rear end problems on S (KID808)
I dunno and would like to know as well. My rear is kinda noisy too.
Old Aug 23, 2005 | 09:51 PM
papa5murf's Avatar
Default Re: Explain typical rear end problems on S (spoon.eg)
you'll hear a clicking sound or a buzz from the rear end..... and you want to catch it before it completely goes kaput.. otherwise you're gonna be fucked with towing bills
Old Aug 23, 2005 | 10:09 PM
Mr. Lucky's Avatar
Default Re: Explain typical rear end problems on S (03s2kblue)
is it noticable? i'm wondering the same thing.
Old Aug 23, 2005 | 11:46 PM
papa5murf's Avatar
Default Re: Explain typical rear end problems on S (bs-inc.s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bs-inc.s2k &raquo;</TD></TR><TR><TD CLASS="quote">is it noticable? i'm wondering the same thing. </TD></TR></TABLE>
yeah buddy.... it's noticeable... the worse it is.. the louder it'll be...
Old Aug 23, 2005 | 11:47 PM
papa5murf's Avatar
ohhh and it should be a constant noise... you'll hear it all the time when you're rolling..
Old Aug 24, 2005 | 02:57 AM
s2kkk's Avatar
What is it? Axel nut? Maybe low on diff fluid?
Old Aug 24, 2005 | 01:30 PM
Mr. Projekt's Avatar
* B A N N E D *
Check the diff fluid level? How about your CV joints on the half shafts? Or wheel bearings? Noises coming from the "rear end" isn't very specific, especially when you hear them from the driver's seat.
Old Aug 25, 2005 | 04:20 PM
s2kkk's Avatar
Default Re: Explain typical rear end problems on S (Sideways2000)
The clicking I hear is when I'm slowing down. Do about 17MPH in 2nd gear in your S2K and just let off the gas. The click coming from my rear sounds like the wheel in wheel of furtune.
Old Aug 25, 2005 | 04:34 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg &raquo;</TD></TR><TR><TD CLASS="quote">The click coming from my rear sounds like the wheel in wheel of furtune. </TD></TR></TABLE>
Sounds to me like you may need to buy a vowel.
Old Aug 25, 2005 | 07:26 PM
papa5murf's Avatar
Default Re: Explain typical rear end problems on S (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds to me like you may need to buy a vowel. </TD></TR></TABLE>
:rofl:
Old Aug 25, 2005 | 08:01 PM
s2kkk's Avatar
What vowel may I buy?
Old Aug 25, 2005 | 08:09 PM
negcamber's Avatar
Common issue is the rear center hub nut (or spindle nut). Tighten the center hub nut to 220lb...if the click stops then you have your fix. Unfortunately, the loose nut will probably have caused some premature wear on the wheel bearings. You will have bought some time once you have tightened the hub nut, but you will probably need to replace the bearing fairly soon (and possibly the hub as well...inspect it to see once the bearing is out).
Note: If you let the spindle nut go loose for too long, that click will turn into a squeal and the bearing will be shot and hub ruined for sure. Expect ~$150 for bearing and hub each side.
Old Aug 26, 2005 | 10:05 AM
555R's Avatar
Default Re: Explain typical rear end problems on S (negcamber)
well i know the rears are pretty weak to abuse
Ive sold a few Kaaz LSDs with the comptech rear housing
no problems there
now the axles break
time to start selling better axles
Old Aug 26, 2005 | 05:38 PM
revhi's Avatar
Constant clicking doesnt sound like the spindle nut. That would be just a single click or 2 when starting or downshifting. Basically any intial load on the wheels.
Old Aug 26, 2005 | 10:18 PM
s2kkk's Avatar
Going to change the differential fluid tomorrow. Its probably either a little low, or the rear is going. Oh well, its under warranty.
Old Aug 27, 2005 | 04:37 AM
s2kkk's Avatar
Just noticed that the rear doesnt click when the car is cold. Once its warmed up from driving, its starts to click. My only guess is the differential fluid.
Old Aug 27, 2005 | 06:25 AM
speed4tu's Avatar
I had a rear diff to blow, and befor it did it made a constant roaring like sound. It made this noise for a while, and finally a gear broke and the whole housing broke apart. Had to replace everything.
Old Aug 27, 2005 | 08:51 AM
negcamber's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Constant clicking doesnt sound like the spindle nut. That would be just a single click or 2 when starting or downshifting. Basically any intial load on the wheels. </TD></TR></TABLE>
And do you know what it sounds like when you let it go for too long? Having just had this happen on my car, I can tell you that the clicking grows progressively worse to the point that it sounds like a bad CV joint, and then to the classic squeal of a bad bearing.
Old Aug 27, 2005 | 08:57 AM
s2kkk's Avatar
Is there any kind've recall from Honda for the rears in the S2K's? This blows and its a known problem for ALOT of people. We should start a petition and sent it to honda.
Old Sep 3, 2005 | 09:21 AM
KID808's Avatar
New User
Default Re: (spoon.eg)
I did find a TB on this it had to do more with the half shafts. It explained to take them off and you needed to put a special silicone grease in there. They explained the problem as a grunt at low speeds or turns.
BTW if one was to switch out the rear end what are the options available?
And what ratio?
Old Sep 3, 2005 | 10:25 AM
* B A N N E D *
Default Re: (KID808)
Rick's or J's gears: 4.3, 4.44, 4.7, 4.9, 5.1
Old Sep 25, 2005 | 12:03 PM
KID808's Avatar
New User
Default Re: (Sideways2000)
Sorry to bring this back from the dead. Put i have fixed my noise problemwith my rear end. I purchased a car with a slight clunk or grunt when at slow speed and starting to turn. The problem had to do with a the rear axel shaft and it needing lubrication.
This only cost me less than 200.00 at the local dealer. Just go there and inquire about a TSB reguarding a grunt at low speeds.
Thanksfor your help.
Good luck
Freefallin99
Honda CR-V & Element
Dec 31, 2022 06:23 PM
seearevee
Jun 4, 2016 10:31 AM
stinkfist2000
Honda S2000
17
Apr 15, 2008 02:05 PM
BiG_DeE
Apr 2, 2008 09:07 PM
spock_rocker
Oct 8, 2004 09:46 AM
