Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake Warning Light in EF Civic... I Give Up
Old Feb 10, 2005 | 12:58 PM
Catch 22's Avatar
Default Brake Warning Light in EF Civic... I Give Up
The brake light came on during an enduro, and I can't figure out why.
I do know what it is NOT at this point...
- Fluid level
- Reservoir cap (replaced it)
- Ebrake switch
- Wiring (that I can find)
- Brake lights (all functioning)
Any suggestions?
I can't find anything helpful in the FSM, and I'm getting ready to just pull the bulb out of the damned thing.
Old Feb 10, 2005 | 01:02 PM
ryan12321's Avatar
Default Re: Brake Warning Light in EF Civic... I Give Up (Catch 22)
mine has it too, but i haven't even bothered to look into it.
from some dealership knowledge I have collected over the years. The MC has the slide which measures fluid level. In cold weather it can stick which will leave the light on. Also aftermarket caps are supposed to suck for this reason and fail quite quickly. As long as my brakes are working and my fluid level is fine I haven't worried about it.
Old Feb 10, 2005 | 01:06 PM
SPiFF's Avatar
Default Re: Brake Warning Light in EF Civic... I Give Up (ryan12321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan12321 &raquo;</TD></TR><TR><TD CLASS="quote">As long as my brakes are working and my fluid level is fine I haven't worried about it.</TD></TR></TABLE>
Righto .. but if I remember correctly, the last 2 times I saw your car at track, the brakes were not working that well.
Old Feb 10, 2005 | 01:12 PM
Catch 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan12321 &raquo;</TD></TR><TR><TD CLASS="quote">The MC has the slide which measures fluid level. </TD></TR></TABLE>
Yeah, I thought that was the problem. I cleaned the original... Didn't fix it.
Then I bought a new OEM Honda reservoir cap... Didn't fix it.
I hate just ignoring warning lights. Its a bad habit.
Old Feb 10, 2005 | 01:15 PM
ryan12321's Avatar
Default Re: Brake Warning Light in EF Civic... I Give Up (SPiFF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPiFF &raquo;</TD></TR><TR><TD CLASS="quote">Righto .. but if I remember correctly, the last 2 times I saw your car at track, the brakes were not working that well. </TD></TR></TABLE>
Overheating and not working is two different things. I hate rear drums too.
Old Feb 10, 2005 | 01:37 PM
Greyout's Avatar
your problem is that there is some sort of bulb that has gotten caught in the socket
Old Feb 10, 2005 | 02:05 PM
RexRacer19's Avatar
Maybe a short in the dash panel? My factory water temp gauge would randomly peg on HOT which would freak me out till I gave the top of the dash a whack...then it would return to the normal reading. It seemed to get worse over time (maybe it did not like the abuse ). Now I have an aftermarket gauge, and the problem went away...
Old Feb 10, 2005 | 02:28 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">- Fluid level
- Ebrake switch
does this include cleaning the contacts at the back of the guage cluster?
Old Feb 10, 2005 | 03:13 PM
Zeppelin's Avatar
Default Re: Brake Warning Light in EF Civic... I Give Up (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">does this include cleaning the contacts at the back of the guage cluster?</TD></TR></TABLE>
This would only be the case if the brake warning light comes on if the circuit is open, but it works when a switch is closed(handbrake or fluid low switches). There is either a short in one of the wires to ground or the "Brake Check Relay" is bad. I do not know where this relay is.
Old Feb 10, 2005 | 03:19 PM
Tyson's Avatar
Default Re: Brake Warning Light in EF Civic... I Give Up (Zeppelin)
who knows if theres anything grounding the back of the cluster as well.
MaWeiTao
Aug 8, 2010 12:49 PM
lilshady6796
Nov 1, 2008 08:33 PM
Z7
10
Aug 6, 2006 01:17 PM
kolohekine
10
Jan 27, 2005 04:44 PM
Understeer
Dec 1, 2003 09:40 PM
