ls/vtec ?
Old Feb 10, 2005 | 08:04 AM
93slmdcvcsi's Avatar
Default ls/vtec ?
I am doing the ls/vtec witha b16 head, b18b block, b16, waterpump, oil pump, and i was trying to find out what head gasket i needed and if it would be a good idea to switch the gear on the crank to a b16. If someone could help i would appreciate it!!
Old Feb 10, 2005 | 08:06 AM
neogenesis2004's Avatar
Default Re: ls/vtec ? (93slmdcvcsi)
Use the ls gear, I'm pretty sure all the timing gears other than the water pump are the same. As for the head gasket, everything I've read states to use a gasket made for the block. I.E. use a ls headgasket. Someone correct me if I'm wrong, I don't want to spread misinformation.
Old Feb 10, 2005 | 08:09 AM
97L-esVeeTeg's Avatar
ls HG, vtec waterpump and timing belt
boosted92hatch
May 29, 2006 08:44 AM
SiBuddy00
Apr 5, 2005 11:42 AM
turbo_b16_ex
Feb 28, 2005 03:13 PM
elusive123
Jul 18, 2004 11:06 AM
