G2 Idle problem (RPMs Fluctuate)
Old Jan 16, 2002 | 04:12 PM
integrals972's Avatar
Default G2 Idle problem (RPMs Fluctuate)
90 LS, @ idle, my rpms fluctuate up and down. Sometimes it stops but most of the time it hits around 1500 rpms then falls back down and then goes back up. This problem occured right after I got my timing belt changed. I already check my Vacuum hoses and I do not have a leak. What else could it be, anyone else had this prblm b4? I think its my Timing *shrug*
Thanks,
Steve*
Old Jan 16, 2002 | 06:05 PM
AGen2integra's Avatar
Default Re: G2 Idle problem (integrals972)
Hey what's up man! I have a G2 and I think i had the same problem... Right before my alternator went bad it was ideling funny just like you posted.. I then did tests on it to see if it was the alternator and the tests proved it to be good.. After a week or two of not finding an answer as to why, I tested it again and i needed to replace it... After that it ran fine..... ???? sounds stupid don't it.........It could be that, or it can't be that. Try testing it. Also is ecu showing any codes?? Oh, one last thing....Did you check the idle control valve??? Anyway, if you find out what is going on with it let me know cause I'm buying a 91 LS beater with same problem and if its something different let me know. later,evan
Old Jan 16, 2002 | 07:29 PM
brinks's Avatar
COuld be a number of things.
Fast Idle thermovalve FITV
IAC valve
bad ECU
air in the coolant
They are all possibilities but the first 2 are very suspect.
Old Jan 16, 2002 | 10:46 PM
GTEater's Avatar
Default Re: G2 Idle problem (brinks)
IAC valve
bad ECU
air in the coolant
all these could be the reason.......also, maybe your timing belt was installed improperly and your motor could be out of time........if so you would feel a good loss of power
mouab18c1
Aug 25, 2007 12:46 AM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
chocolate moose
May 25, 2005 05:58 AM
stoopid_monkey
Apr 26, 2005 11:22 PM
Luke J
Apr 13, 2003 06:05 PM
