oil leak from valve cover
Old Feb 9, 2005 | 08:40 PM
blue2ksi's Avatar
Default oil leak from valve cover
i had an oil leak from my valve cover a couple months ago when i had replaced the gasket with an aftermarket one. i had figured that because it was aftermarket, it was the reason why it had leaked. after finding the leak, i had immediately replaced it with an oem gasket and used gasket sealant on the correct areas. it has been less than 4 months for sure so im wondering why it is starting to leak again. by the way, it's not a severe leak... minor drips
Old Feb 9, 2005 | 08:41 PM
civictildeath's Avatar
Default Re: oil leak from valve cover (blue2ksi)
did you clean the two mating surfaces very well of all old gasket and other debris??
Old Feb 9, 2005 | 08:42 PM
blue2ksi's Avatar
Default Re: oil leak from valve cover (civictildeath)
yes
Old Feb 9, 2005 | 09:43 PM
eK9aT10pSi's Avatar
did you torque the bolts down also ?
Old Feb 9, 2005 | 10:47 PM
EKvTach's Avatar
should take pix of where it is leaking
Old Feb 10, 2005 | 01:57 AM
_Cyclone_'s Avatar
Default Re: (EKvTach)
has the valve cover ever been dropped when off the engine? it could be damaged/bent... you never now. Check torque specs too.
Old Feb 10, 2005 | 04:37 AM
monicle's Avatar
I doubt its a torque issue as those bolts only torque to like 7 lbs. Is it leaking on the passenger side of the motor? If so its most likely the exhaust cam seal which is quite easily fixed.
Old Feb 10, 2005 | 04:48 AM
AutoXer's Avatar
Default Re: oil leak from valve cover (monicle)
Did you use Honda bond or RTV sealant on the gasket?
Old Feb 10, 2005 | 05:28 AM
ScubaStevo80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">I doubt its a torque issue as those bolts only torque to like 7 lbs. Is it leaking on the passenger side of the motor? If so its most likely the exhaust cam seal which is quite easily fixed. </TD></TR></TABLE>
I also use a copper gasket sealant or RTV sealant over the areas where the cam goes into the dizzy and where it attaches to the cam gear. I believe the Helms requires this when installing the valve cover.
Old Feb 10, 2005 | 07:18 AM
alotawatts's Avatar
Did you put sealant where the 90 degree bends are in the gasket ? thats the only place you need it.
Your leak is probably at a corner right ?
Old Feb 10, 2005 | 10:35 AM
blue2ksi's Avatar
Default Re: (CycloneBlue_1.6EL)
no the valve cover has never been dropped
Old Feb 10, 2005 | 10:36 AM
blue2ksi's Avatar
yeah it's leaking more towards the passenger side
blue2ksi's Avatar
Default Re: oil leak from valve cover (EX_AutoXer)
i used some gasket sealant i got from kragen... that should work right? or could that be the problem?
Old Feb 10, 2005 | 10:37 AM
blue2ksi's Avatar
Default Re: oil leak from valve cover (alotawatts)
yes i put it on the corners
Old Feb 10, 2005 | 10:48 AM
dantastic's Avatar
i have a simliar problem on my b18b. the oem valve cover gasket was leaking, so i replaced it with an aftermarket. now its leaking a bit, just over the exhaust manifold. i'm just gonna use a bit of RTV to seal it up some more....
Old Feb 10, 2005 | 11:21 AM
LaosGuySi's Avatar
sifu pai mei
Default Re: (dantastic)
how much oil are you putting in your motor?
Old Feb 10, 2005 | 11:56 AM
_BEN_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">I doubt its a torque issue as those bolts only torque to like 7 lbs. Is it leaking on the passenger side of the motor? If so its most likely the exhaust cam seal which is quite easily fixed.</TD></TR></TABLE>
Its common
Spray down the area with some brake cleaner and monitor where its coming from.
Old Feb 10, 2005 | 01:55 PM
Resident Evo's Avatar
the valve cover has been dropped. You don't know about it is because I never told u. It happened when u went inside ur house and it slipped off my hands. My bad eugene.
Old Feb 10, 2005 | 02:49 PM
monicle's Avatar
Default Re: oil leak from valve cover (EBP-Si)
just call him Mr. Butterfingers.
Old Feb 10, 2005 | 02:57 PM
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP-Si &raquo;</TD></TR><TR><TD CLASS="quote">the valve cover has been dropped. You don't know about it is because I never told u. It happened when u went inside ur house and it slipped off my hands. My bad eugene.</TD></TR></TABLE>
I bet hes gonna need a new valve cover.
Old Feb 10, 2005 | 03:32 PM
adictionbass's Avatar
Default Re: oil leak from valve cover (jlacoy82)
Old Feb 10, 2005 | 04:17 PM
_Cyclone_'s Avatar
I hit the nail on the head.
Sorry about the bad luck bro.
Old Feb 10, 2005 | 05:08 PM
blue2ksi's Avatar
son of a bitch
Old Feb 10, 2005 | 05:09 PM
Default Re: (blue2ksi)
did ebp si sell it to you or something?
Old Feb 10, 2005 | 05:10 PM
jlacoy82's Avatar
71.192.16.183
Its just a valve cover. Dont get too steamed about it.
