External Coil Question
Old Feb 9, 2005 | 06:56 PM
GWInquisitor14's Avatar
Default External Coil Question
I searched and couldn't quite come up with the answer to this question...What is all needed to change my OEM, internal coil, to say an MSD external coil ignition. I plan on going turbo and im probably gonna need a good ignition with the added boost. I know i need the coil and the modified cap, but on MSD's webpage they say a certain ignition system is needed. I am not too familiar with aftermarket ignitions so if someone could give me the basics and what i need thatd be great.
Old Feb 9, 2005 | 09:49 PM
Lord Helmet's Avatar
Default Re: External Coil Question (GWInquisitor14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">I searched and couldn't quite come up with the answer to this question...What is all needed to change my OEM, internal coil, to say an MSD external coil ignition. I plan on going turbo and im probably gonna need a good ignition with the added boost. I know i need the coil and the modified cap, but on MSD's webpage they say a certain ignition system is needed. I am not too familiar with aftermarket ignitions so if someone could give me the basics and what i need thatd be great.</TD></TR></TABLE>
A 6AL or 6A BTM will be fine with the turbo unless you plan to boost alot 20+ PSI then the 7 series will be a good choice.
Here's the list of instructions you need: http://www.msdignition.com/1download.htm Has everything you need to properly install your ignition system.
Old Feb 10, 2005 | 06:57 PM
Default Re: External Coil Question (sleeperciv)
thanx for the site but unfortunatly i cant access it, it always freezes up whenever i try to go into the adobe acrobat. If anyone has a list of parts and maybe a brief explanantion, thats what im looking for
Old Feb 13, 2005 | 09:41 AM
bump
93hatchboosted
Jul 10, 2004 01:51 PM
4inspeed
Feb 9, 2004 01:13 AM
marques4130
May 9, 2003 06:24 PM
turbo sol
May 5, 2003 06:38 AM
integrasi
Mar 5, 2003 12:28 AM
