suspension interchangability between 90-93 and 94-01???
official honda whore
well i have a 94 gsr parts car and a 93 ls integra that desperately needs some parts
would the shocks front and rear be compatible?
would the front upper a arms be compatible?
would the outter tie rod ends be compatible??
thanks for any answers
Here's a free fump and some information I have to offer. The upper a arms are not compatible. I say this because the Skunk2 upper a arm camber kit doesn't fit, so I wouldn't imagine the stock ones would either. The front shocks are compatible as long as you use the forks from the 94+ teg. somebody help him out with some more help
not sure about fronts, but i just picked up a set of lower control arms for the rear off of a DA integra and it bolted up beautifully into my DC2, so im guessing the DA stuff will fit DCs as long as the DA has independent rear suspension, because some DAs have solid rear axles (like CRXs). fronts sound like they should work (springs/struts) if you use the DC damper fork. good luck man, just had the same question a few days ago, and got it figured out of my own, so i thought i'd throw my $.02 in here.
independent suspension from DA = interchangable for DC for the rear at least. just look at the 2 cars and compare, you can tell if itll fit or not just by looking at it and doing a little measuring. hope this helped.
well i got sick of my car handling like **** and goin all over the road, so i switched out the outter tie rods with ones from a 94 up gsr and they worked, im going to get it aligned tomorrow and i will let you all know how it turns out
btw its still rough and sounds like its hitting really hard when i hit a bump? what could this be,
and how do i tell that the inner tie rod is bad, icould spin the rod around freely when i took the outter tie rod off
brian
brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">im no suspension guru, but im gonna say the clanks and rough ride over the bumps is upper a-arms....someone correct me if im wrong</TD></TR></TABLE>
you always post what im telling you on aol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote">
you always post what im telling you on aol </TD></TR></TABLE>
its a free bump, plus im puttin up so ppl can say if im wrong or not...and u dont believe me anyways, asking the same question i answered for u
The upper A arms are pretty easy to find out if they are bad. Just jack up the front and and start yanking on the tire. I had real bad play in those upper balljoints mainly because there was no grease left in them. I looked and looked and couldn't find anywhere that sold just the balljoints. Places wanted like $120/piece for each A-arm too. I ended up just pulling some lower mileage A-arms from the junkyard with good balljoints. That's the one good thing about a DA, there are a decent amount of them in junkyards.
aquito
Oct 22, 2010 11:29 AM
