Bumper is sag issue!! URGHHH!
hey wats up guys, i have a terrible sag issue with my front end... Im thinking could I just replace my Radiator Support?? Because the part where the bumper bolts up to the FRAME, that part is kinda fucked up... need help!
Heres a pic to kinda help you guys out..
is your core support bent or sumtin, have you ever been in any accidents because core supports are a bitch to take out and put a new one in, you have to drill all the spot welds out and its not very fun.
that car woud've looked sweeter if you painted the mirrors black and the sideskirts.but anyways i would just change the radiator support.
Looks like your front end was in a previous accident. If you pay close attention to the driver's side fender, it's off from the hood. I am not sure if a new rad support will fix it if the mounting point is bent.
front end looks like a collage.. def bodyshop candidate
anybody have this corrected before? can it be bent back, or would it involve new parts and a big bill?
Looks like lining up issues. One thing it could be the core /radiator support. Next thing it could be is hood/bumper/fender alignment. Ive had the fender not match up with the hood as seen in your pic, but it was fixed with moving the hood a little back and turning those height adjusters found under the hood, on the core support and raised up to the height of the fenders.
Peace and gluck
Peace and gluck
Try taking off your front bumper and lifting up the sagging side by the bumper support and such with a big Jack or something. Try straightening the radiator support if it is a lil bent on the top part. If it doesnt help, then the best thing would be taking your car to a body shop or somebody with experience.
Good Luck
Good Luck
Do a visual inspection first, with the bumper off. If it's something you can fix yourself, more power to you. But yeah that hood needs some adjusting
i took my bumper off and i tried hitting the part where the bumper bolts up with a hammer to bend it up because i think that is the issue.. NO WORKY... what else can i use?? THIS **** IS BLOWER
I bought the car last year and when i bought it, it was like this and i havent gottin into any acidents since.**KNOCK ON WOOD 3 times**
my front end is a bit unaligned too. i went to a body shop and they said they'd realign it for like $100. in my case, everything lines up correctly except where the hood meets the bumper. you can literally touch the hood latch while the hood is closed.
supaman111
18
May 7, 2023 06:15 AM
JDM2317
Mar 15, 2010 03:51 PM
