Fuel injectors
Old Feb 9, 2005 | 03:21 PM
locoSIR20's Avatar
Default Fuel injectors
im getting a clicking noise, gas smell from my injectors i checked them and one of them feels really loosedcompared to the others are they shot or can this be fixed? car feels fine...
Old Feb 9, 2005 | 03:25 PM
dantastic's Avatar
Default Re: Fuel injectors (locoSIR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locoSIR20 &raquo;</TD></TR><TR><TD CLASS="quote">im getting a clicking noise, gas smell from my injectors i checked them and one of them feels really loosedcompared to the others are they shot or can this be fixed? car feels fine...</TD></TR></TABLE>
a bit of clicking is normal. is there fuel leaking from them? have ou done any work to the fuel rail at all? you might have to replace the o-rings that make the seal between the injector and fuel rail. i replaced my fuel rail, and it's really easy to pinch those rings.
locoSIR20's Avatar
i was told that theres rubber piece that the injector sits in that dry rots.....
BauleyCivic's Avatar
Risky Business
The seal might be bad...by loose do you mean you can jiggle it around in the intake manifold?
Old Feb 9, 2005 | 03:26 PM
locoSIR20's Avatar
Default Re: Fuel injectors (dantastic)
yeah i removed them and put them back a while ago does this mean the o ring is shot? or do they just have to be reset...
Old Feb 9, 2005 | 03:28 PM
locoSIR20's Avatar
Default Re: Fuel injectors (BauleyCivic)
one of them i can twist real easy im not getting n e fuel leaks or anything
Old Feb 9, 2005 | 03:48 PM
locoSIR20's Avatar
where can i get replacement o rings?
Old Feb 9, 2005 | 03:57 PM
jlacoy82's Avatar
71.192.16.183
Honda dealership.
Old Feb 9, 2005 | 04:05 PM
SOHCD16y8's Avatar
prolly the rings, you should always replace them when working with injectors just to be safe
Old Feb 9, 2005 | 04:09 PM
ABK's Avatar
ABK
Default Re: (SOHCD16y8)
yeah if you are going to replace them use some vasoline or something so you don't rip them.
410ruga
Apr 10, 2014 03:46 AM
kaspa35
Aug 18, 2008 11:50 AM
mw011i
Jul 18, 2008 05:06 AM
EJ8VTEC
Sep 30, 2005 11:14 AM
baonest
Aug 5, 2001 02:51 PM
