window rolls up too far!!!!!!!!!!!!
Old Feb 9, 2005 | 02:52 PM
WHiTETYPEs's Avatar
Default window rolls up too far!!!!!!!!!!!!
I have a 1998 civic EX coupe with power windows and when I roll my window up on the driver side its like it wants to keep rolling the window up and makes the window jump repeadetly like it wants to keep pushing the window up??? how do I fix this?
Old Feb 9, 2005 | 03:42 PM
eg6sir-s's Avatar
Default Re: window rolls up too far!!!!!!!!!!!! (eK9RepreSenT)
take off your panels. check the window rails. make sure the glass is fastened down tight on the rail.
Old Feb 9, 2005 | 03:51 PM
2kstreetcivic's Avatar
Default Re: window rolls up too far!!!!!!!!!!!! (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">take off your panels. check the window rails. make sure the glass is fastened down tight on the rail.</TD></TR></TABLE>
werd..thats what I would do
Old Feb 9, 2005 | 04:06 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: window rolls up too far!!!!!!!!!!!! (2kstreetcivic)
Yes do that first. If you find out that everything mechanical is in good working order, it is probably the sensor that senses the resistance when it reaches the top or bottom. That's on the harness under the dash.
Old Feb 9, 2005 | 06:14 PM
WHiTETYPEs's Avatar
Default Re: window rolls up too far!!!!!!!!!!!! (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
Yes do that first. If you find out that everything mechanical is in good working order, it is probably the sensor that senses the resistance when it reaches the top or bottom. That's on the harness under the dash.</TD></TR></TABLE>
would i ahve to buy a new harness or how would i fix the harness?
Old Feb 9, 2005 | 06:34 PM
Tapen00n's Avatar
same thing happened to me in my 97 ex. replaced the regualtor and it works perfect now
Old Feb 9, 2005 | 08:01 PM
93civicsedan's Avatar
Default Re: window rolls up too far!!!!!!!!!!!! (Tapen00n)
same thing happened to me and I just replaced the window rubber.
Old Feb 9, 2005 | 08:57 PM
litterbox's Avatar
Default Re: window rolls up too far!!!!!!!!!!!! (93civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9RepreSenT &raquo;</TD></TR><TR><TD CLASS="quote">
would i ahve to buy a new harness or how would i fix the harness?</TD></TR></TABLE>
I wouldn't know really. It's probably the regulator though.
lokuntry
Aug 3, 2008 04:23 PM
stock99si
May 20, 2007 06:30 PM
george34
Sep 27, 2006 07:23 PM
djfob
May 8, 2006 02:09 PM
iwhichisme
May 2, 2003 11:28 AM
