4th Gen experts....
Any of the models have roll up windows? Does the S model? I have power windows, and I am trying to get rid of some weight (don't need power windows in a racecar)... I was thinking they all had power windows, I guess I am just hoping that maybe the S would have roll up windows..
Roll up windows aren't going to give you lots of weight reduction. Tip: you will get better weight reduction taking a before you race than you will with roll up windows. Why don't you get a carbon fiber shift ****, and shave off a few more ounces.
Well, it is more than JUST weight reduction, but thanks for the smart comment.. Its either roll up windows, or no windows at all.... And don't think I am just some kid racer just trying to loose a couple lbs for the next street race..
If anything call Honda and ask to see if the 92 Preludes has the roll up windows, I seriously doubt thou. GOOD IDEA thou. Ever thought of removing the bumper supports.
Im confused, what else would you gain without power windows?
Wel if you really have the time, you can always custom make roll up window or make some brackets to keep it closed ay all time...I agree with you on the Bumper supprts, just an idea. What about getting rid of the factory tank and get a lighter tank. I see some fuel tanks on Summit magazine
It was a joke..calm down. BTW, are you trying to say that roll windows opposed to auto's are a signifigant weight diff?
If you don't mind doing some work you should be able to fabricate some lexan windows that can snap in or be bolted on when you want them and taken off when you don't.
yeah, customizing is your best bet... try posting this at http://www.hondaprelude.com if you already haven't. maybe you'll get more help there. maybe someone already tried doing it... you never know...
there is only a couple pounds difference between the two. The units themselves on the power window actuators only weight around 7lbs, give or take. It would be better just to take out the passanger side seat. I think the biggest problem with wieght on these cars are the 22lbs a wheel plus tire. If ya got money tho all lexan would be nice. Another way to lose weight, you can always tell her to walk.
I'm with the thought of the lexan windows. I realize that they're illegal for track use, however, with a snap on system and some weather stripping, you'd be set.
Therefor you have "windows" on the street, but at the track, in 5 minutes or less, you're stripped of them.
Roll up windows in a prelude..how dare honda!!
jk
I am not sure about this?? Did they have a base model in the 4th gens?
this might have roll-ups!
I am with a few other guys on this....you should fabricate your own. Lexan...
jkI am not sure about this?? Did they have a base model in the 4th gens?
Remember guys, my car is a racecar... There is NOTHING inside of it other than safety gear, a driver's seat, and steering wheel.. Unfortuanlly, Lexan windows are against the rules.. I am running Kosei K1 wheels, 13lbs in 15x7" and only 120$... If a bitch wants to ride with me, she can sit on the damn floorboard.. With it being cold, it will get her *** nice and tight
hahaha... i
tight asses too, but after a few
and a few
they are all the same.
or maybe she can ride on the stick
she'd probably get all
because she has nowhere to sit, but it's all
as long as you're
with your
hahaha... i
and a few
they are all the same. or maybe she can ride on the stick
as long as you're
with your
92integraVTECgsr
25
Feb 28, 2007 01:40 AM
