does a b16 water and oil pump flow...
Old Jan 16, 2002 | 01:09 PM
BoostinDC2's Avatar
Default does a b16 water and oil pump flow...
does a b16 water and oil pump flow the same as a gsr water and oil pump. cause what i want to do is put the b16 oil and water pump on my gsr since its a lil cheaper but will this affect performance
Old Jan 16, 2002 | 02:20 PM
Turboholic's Avatar
Default Re: does a b16 water and oil pump flow... (BoostinDC2)
I believe them to flow the same volumes, so, yes you can use them.
Old Jan 16, 2002 | 06:04 PM
FitCRX's Avatar
Default Re: does a b16 water and oil pump flow... (Turboholic)
Why would they be cheaper..if its the same pumps?
Old Jan 16, 2002 | 07:26 PM
rainforest's Avatar
Default Re: does a b16 water and oil pump flow... (FitCRX)
yes they are the same look. belive me.
Old Jan 17, 2002 | 11:57 AM
BoostinDC2's Avatar
Default Re: does a b16 water and oil pump flow... (rainforest)
its cheaper cause it comes from the honda dealer. if i were to buy the same parts at an acura dealer they would be atleast $10 more
Old Jan 17, 2002 | 12:34 PM
Mike K's Avatar
Here's the numbers(all rated at 6,000rpm)
B16A oil pump 53qpm
B17A oil pump 54qpm
B18C oil pump 75qpm
B18B oil pump 53qpm
B16A water pump 140qpm
B17A water pump 140qpm
B18C water pump 148qpm
B18B water pump 148qpm
For those who huff butane:
qpm = quarts per minute
stockbee
Mar 25, 2008 06:26 AM
boostedb18kid
Nov 10, 2007 02:10 PM
zCivic
May 22, 2003 04:41 PM
Malgerus
Jan 11, 2003 04:33 AM
