d15b vtec build..
Old Feb 8, 2005 | 08:15 PM
ALLMOTA92EG's Avatar
Default d15b vtec build..
well im wanna do a single cam all motor build using a d15b, but can i use parts for the d16z6 because thats all i can find on websites?
Old Feb 9, 2005 | 12:01 AM
Bambooseven's Avatar
Default Re: d15b vtec build.. (xthehardedgex)
some of the parts you can, some you cannot. which parts are you talking about?
Old Feb 10, 2005 | 11:15 PM
No_Fear's Avatar
will camshaft ,for example skunk2 camshaft for D series work in D15b ?
Old Feb 10, 2005 | 11:25 PM
Uncle Ben's Avatar
Default Re: (No_Fear)
^I believe so. The d15b and z6 are almost identical. I recently put a d15b head on my z6, I can actually feel a little more on the butt dyno.
Old Feb 11, 2005 | 12:36 AM
Default Re: (Uncle Ben)
both heads are P-08 castings, the cam should work fine.
Old Feb 11, 2005 | 04:19 AM
TheBlackCrx's Avatar
Default Re: (Bambooseven)
the d15b vtec head comes with a more agressive cam so you most likely are making a little more power
Old Feb 11, 2005 | 04:37 AM
joboost13's Avatar
Default Re: (TheBlackCrx)
use some b7 or jdm zc pistons 2 bupm up the cr if u going all motor
Old Feb 11, 2005 | 09:44 AM
No_Fear's Avatar
thanks guys,it will be nice if the skunk2 cam will fit on the D15b
Old Feb 11, 2005 | 10:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheBlackCrx &raquo;</TD></TR><TR><TD CLASS="quote">the d15b vtec head comes with a more agressive cam so you most likely are making a little more power </TD></TR></TABLE>
that is a myth.
Old Feb 14, 2005 | 10:18 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bambooseven &raquo;</TD></TR><TR><TD CLASS="quote">that is a myth.</TD></TR></TABLE>
the fact that it's a myth is a myth.
in other words its the truth.
the d15b's cam rocks.
dont have the link off hand, but someone did dyno tests comparing the d15b cam,
, and zex stg1,
the d15b cam was just as good as the zex, and better in some aspects.
Radim
Jul 30, 2008 09:09 AM
SLO Sol
Jul 23, 2007 07:32 PM
kantfadedisazn
Jan 3, 2006 02:33 PM
Simple SOHC
12
May 14, 2004 11:32 AM
bla1ne
13
Jan 7, 2004 09:03 PM
