under dive pulleys??
Old Feb 8, 2005 | 07:52 PM
sloweredcivic's Avatar
Default under drive pulleys??
do underdrive pulleys actually work? how much power do they add or is kinda you just notice it driving around kinda thing??
Old Feb 8, 2005 | 07:55 PM
90LSpimpin's Avatar
Default Re: under dive pulleys?? (sloweredcivic)
They work, but i've read that they can be a danger to your motor due to them being not properly balanced. The oem honda crank is balanced by the pulley, which is why it weighs what it does. I guess u could use it for the alternator, or ac, but it probly isnt worth it. Search around a little, try to find a post by MistaBone about this, he had a motor do some nasty things from installin underdrive pulleys.
Old Feb 8, 2005 | 08:02 PM
untitled's Avatar
Default Re: under dive pulleys?? (89SiPimpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">They work, but i've read that they can be a danger to your motor due to them being not properly balanced. The oem honda crank is balanced by the pulley, which is why it weighs what it does. I guess u could use it for the alternator, or ac, but it probly isnt worth it. Search around a little, try to find a post by MistaBone about this, he had a motor do some nasty things from installin underdrive pulleys.</TD></TR></TABLE>
Its not so much the balancing, its the fact that they arent harmonic dampers.
A factory crank pulley dampens vibrations that the crankshaft gives off from rotating that would destroy the bottom end bearings.
Old Feb 8, 2005 | 08:04 PM
what about the aem tru power pulleys??
90LSpimpin's Avatar
Default Re: under dive pulleys?? (untitled)
Yea thats what i meant, couldnt remember what else it was. Thx, you and you're mob are awesome
Old Feb 8, 2005 | 08:06 PM
thatbluecrx's Avatar
i had aem underdrive pully on my stock d15 crx altenator and my lights would dim like crazy unless i revd not worth it imo
Old Feb 8, 2005 | 08:12 PM
ssl2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats what i meant, couldnt remember what else it was. Thx, you and you're mob are awesome </TD></TR></TABLE>
awesome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">i had aem underdrive pully on my stock d15 crx altenator and my lights would dim like crazy unless i revd not worth it imo</TD></TR></TABLE>
Did you adjust your belt correctly?
It shouldn't have dimmed what so ever.... engine RPM is going to stay the same for idle .... and it doens't matter how much your rotating assembly weighs for how fast it spins the alternator wheel...
Old Feb 8, 2005 | 08:20 PM
crxgator's Avatar
Default Re: under drive pulleys?? (sloweredcivic)
if you have a d16a6, the harmonic balancer is in the oil pump and you can run the light weight crank pulley without any problems...according to the guys in the RR/Auto-x forum...
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">
A factory crank pulley dampens vibrations that the crankshaft gives off from rotating that would destroy the bottom end bearings. </TD></TR></TABLE>
Here this argument goes again...*sigh*...and i still havent found the answer ive been looking for. One of the 88-91 Civic D series motors (I think HF and LX's?) came with a pulley that did not have the rubber ring. It was lighter in weight compared to the D16A6 one. WHY did honda do this? Again, it was a stock OEM pulley.
Old Feb 8, 2005 | 08:21 PM
Default Re: under drive pulleys?? (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">if you have a d16a6, the harmonic balancer is in the oil pump and you can run the light weight crank pulley without any problems...according to the guys in the RR/Auto-x forum... </TD></TR></TABLE>
Maybe u just answered my question...at least partially...
Old Feb 8, 2005 | 08:24 PM
untitled's Avatar
Default Re: under dive pulleys?? (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Here this argument goes again...*sigh*...and i still havent found the answer ive been looking for. One of the 88-91 Civic D series motors (I think HF and LX's?) came with a pulley that did not have the rubber ring. It was lighter in weight compared to the D16A6 one. WHY did honda do this? Again, it was a stock OEM pulley.</TD></TR></TABLE>
I am well aware of this argument and this is my side of it.
You want you car to go fast put it on, becasue most engine builds wont be lsating 50k plus miles, go for it.
Old Feb 8, 2005 | 08:28 PM
ssl2k's Avatar
The LX's had a small *** pulley...
**** it... d series...dime a dozen y0
Old Feb 8, 2005 | 08:32 PM
Default Re: under dive pulleys?? (ssl2k)
Im not a d series guy, rather just trying to understand this whole thoery/fact about the rubber elastomer aiding in longevity of bearing life.
Old Feb 8, 2005 | 08:36 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Im not a d series guy, rather just trying to understand this whole thoery/fact about the rubber elastomer aiding in longevity of bearing life. </TD></TR></TABLE>
In hardcore physics it will, but honda engine are genreally very well balanced from the factory. Go look on an old SBC and see hoe hardcore the dampers are on them...
black94lude
Jul 13, 2009 10:22 AM
itgrowsind
Sep 4, 2008 05:23 PM
1xfastxhatch
10
Apr 25, 2008 09:03 AM
EGB18C
Jan 27, 2008 07:35 AM
sickerhatch
Sep 28, 2005 06:24 PM
