Pulley?? Unorthodox or OEM Balanced/Shaved
If I shave/balance my oem pulley will I still be able to use my ac and ps??
Which route should I go purchase an unorthodox Ultra S or ultra R or oem+shaved/balanced?
Re: Pulley?? Unorthodox or OEM Balanced/Shaved (itgrowsind)
I wouldn't get unorthodox. They are not harmonically balanced pulleys. I would get this:
http://www.fluidampr.com/HONDA.htm
The street version will allow you to run PS, and A/C. The Comp series deletes PS and A/C.
Re: (itgrowsind)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgrowsind »</TD></TR><TR><TD CLASS="quote">since you say the unorthodox crank pulley is not harmonically balanced what bad does this bring?</TD></TR></TABLE>
Vibrations that they say can shorten your engine's life or kill it
Re: (sageuvagony)
just a waste of money unless if your around 500hp.
just a rough outline of parts per hp, but a good refrence point. http://www.evans-tuning.com/te....html
Re: (.I.Need.Money.)
a harmonic balancers like a condom - yes you may not always need one, but you will feel alot safer if you got one.
or so how i look at it... check out the link i posted above, that should give you a good outlook on building a motor.
billard
05-20-2011 10:05 PM
