removing badges
Old Feb 8, 2005 | 01:38 PM
jayare05's Avatar
Default removing badges
i want to remove my badges on the back.. i no the middle honda badge has holes behind it.. how bout the civic and ex ones?
Old Feb 8, 2005 | 01:42 PM
chemical's Avatar
Default Re: removing badges (jayare05)
the civic and EX badges are stickers..?
Old Feb 8, 2005 | 01:43 PM
dfoxengr's Avatar
Default Re: removing badges (chemical)
read his profile "ek coupe"
they dont have holes im pretty sure.
SL!M's Avatar
on the 92-95 civics they are stickers, so some adhesive remover and razor blade will take care of that in the rear. Sorry didnt know you had an EK, im not sure then.
Old Feb 8, 2005 | 01:44 PM
dfoxengr's Avatar
Default Re: (SL!M)
you should NOT run a razor over paint
Old Feb 8, 2005 | 01:45 PM
Lmgrcivic's Avatar
Default Re: (SL!M)
the EK is just a adhesive also on the civic and the EX badge
Old Feb 8, 2005 | 01:50 PM
jayare05's Avatar
Default Re: (Lmgrcivic)
yeah i no using a razor is a bad idea on paint.. i was just curious caz i dont wanna remove them then have holes showin.. imma just put a heat gun to them and they should peal right off them if thats the case. thanks for the replys
Old Feb 8, 2005 | 01:52 PM
93egSIboi's Avatar
to remove the stickers just get a hair dryer and heat them up a bit. after about 10 seconds they should be easy enough to peel off. the stickers will most likely leave some residue behind so buy some adhesive remover like goo gone or something to wipe it off. it should look like the sticker was never there, but sometimes depending on how old the car is, if you look at spot where the sticker was you can barely see the outline. this is due to the paint underneath being basically brand new and the paint around it being duller because of age.
Old Feb 8, 2005 | 01:53 PM
BDogggUT34's Avatar
Default Re: (jayare05)
fishing line works good too
Old Feb 8, 2005 | 01:59 PM
chemical's Avatar
Default Re: removing badges (93egSIboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSIboi &raquo;</TD></TR><TR><TD CLASS="quote">to remove the stickers just get a hair dryer and heat them up a bit. after about 10 seconds they should be easy enough to peel off. the stickers will most likely leave some residue behind so buy some adhesive remover like goo gone or something to wipe it off. it should look like the sticker was never there, but sometimes depending on how old the car is, if you look at spot where the sticker was you can barely see the outline. this is due to the paint underneath being basically brand new and the paint around it being duller because of age. </TD></TR></TABLE>
Yup, I removed them off my old EK they are just stickied on but you will need to scrub hard and use goo gone.
Old Feb 8, 2005 | 02:07 PM
jayare05's Avatar
yeah there off now.. didnt even need a heat gone.. peeled them off and used goo gone. all gone! thanks guys
Old Feb 8, 2005 | 03:09 PM
SL!M's Avatar
Default Re: (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">you should NOT run a razor over paint </TD></TR></TABLE> you are right, i completely forgot. I wasnt thinking. Sorry. I am an idiot sometimes.
Old Feb 10, 2005 | 04:53 AM
YellowCVC98EK's Avatar
From: Fairmont is kinda like hell, the only difference, is Fairmont has a polluted river that runs through, the middle of it.
Yeah on the EK they are stickers. Either heavy fishing line or a guitar string works well. And towards removing the glue, you can get 3939 from any store that sells auto. paint. It works really well as a degreasor and will not damage paint or clearcoat. Good Luck.
YellowCVC98EK.
Old Feb 10, 2005 | 06:47 AM
civictunr_ls's Avatar
hey to get the badges off take a putty knife wrap it in ducttape and use a heat gun as u heat it u can peall it right off and the ducttape will stop it from scratching the paint.
C2daIzZle
Sep 24, 2005 09:03 PM
Prettyboy01
21
Aug 19, 2004 11:26 AM
EKDreamin
Aug 16, 2004 03:24 AM
civicboy95
24
Jul 15, 2004 03:52 PM
