need opinions on what is wrong with my R?
Old Feb 8, 2005 | 01:33 PM
blktyprgrl's Avatar
Default need opinions on what is wrong with my R?
2001 Type R 90,000 m. Just had major service done: timing belt, water pump, cam\crank seals, and every fluid changed. It's burning a large amount of oil,(i topped it off last week and today there was no oil on the dipstick) but there is not a lot of smoke and what smoke there is it's mainly black and only accelerating at WOT. There are no oil leaks. This car is a daily driver and is NOT beat on except the occasional trips to the mountains.
The car has basic bolt-ons, cam gears, and hondata s100. The hondata + tuning made absolutely no gains in hp or torque over stock, and the tuner did little to change the a/f curve (13:1 through out) , however he did set the vtec too low in my opinion at 4950. Which at 90mph i'm in vtec!! I did a compression test on my car and the numbers were 210-205-205-210. I'm going to put the stock ecu back in so I can avoid being in vtec so much, and re-do the compression test tonight and i'll post the numbers up. I'm also going to get a leakdown test done and post those results as well.
I would just like to know what anyone opinions are on this problem, suggestions on what to do/how to fix it or if i would be better off just buying a new block? I guess what i'm asking is, what are my options in fixing this problem and which would be the more cost effective one?
thanks in advance.
Modified by shaniquoi0177 at 5:47 PM 2/8/2005
Old Feb 8, 2005 | 01:37 PM
Bbasso's Avatar
Default Re: need opinions on what is wrong with my R? (shaniquoi0177)
If the tuner made no gains with the Hondata then there is your first problem. Try someone else. a simple VAFC makes gains...
did you check you antifreeze for oil contamination?
Old Feb 8, 2005 | 01:45 PM
blktyprgrl's Avatar
Default Re: need opinions on what is wrong with my R? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
did you check you antifreeze for oil contamination? </TD></TR></TABLE>
i assume that the shop that did the water pump would have told me if there was. This service was done less than a month ago. And I took my car to the same shop today for this problem and had the oil changed and there was no mention of it today either.
Old Feb 8, 2005 | 01:49 PM
mikehonda's Avatar
210-205-205-210 is way high for leakdown. More than likely oil is passing the rings. At least thats what those numbers say. Black smoke is fuel, to much. Hondata is known for that. Find another tuner. Another possible I've seen is "washing " the piston rings, that is too much fuel going into the combustion chamber with knowwhere to go.
Find another tuner, you should get at least 10-20HP from your mods. Once the tune-up is right drive around a while to clean up the motor. Then do your leakdown test, at operateing temp. of course...
Old Feb 8, 2005 | 02:06 PM
RTW DC2R's Avatar
first things first, get a new tuner. that is way too rich on a lightly modified R motor.
second, it sounds like your rings are pretty worn. I had the same problem with very little smoking but burned through oil pretty quickly if I beat on the car. check your plugs and see if you have any particle buildup on the electrodes. and as rob said, check your coolant to see if any oil is floating around in there which would indicate a head gasket problem. be sure to check UNDER the cap as well as sometimes you will get some oil buildup on the cap itself.
Old Feb 8, 2005 | 02:09 PM
blktyprgrl's Avatar
Default Re: need opinions on what is wrong with my R? (mikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikehonda &raquo;</TD></TR><TR><TD CLASS="quote">210-205-205-210 is way high for leakdown.</TD></TR></TABLE>
those are numbers from the compression test
and basically what everyone is saying i got screwed on the tuning? Funny how it was tuned by the "best tuner" in the area (i dont want to give away who it is for the sake of creating drama) I guess I just made the mistake of getting it tuned during race season.
If anyone knows of a good tuner in the southeast, I'm willing to drive to get the job done right.
Old Feb 8, 2005 | 02:17 PM
RTW DC2R's Avatar
P1 auto is your friend.
if you didnt make any power compared to your base runs, then yes it sounds like you got screwed. and in fact i would have been pretty pissed off.
Old Feb 8, 2005 | 04:44 PM
blktyprgrl's Avatar
Default Re: (RTW Ryan)
yeah, I've heard P1 is the place to take it. Where exactly is it located?
Old Feb 8, 2005 | 04:48 PM
Nishant's Avatar
Default Re: (shaniquoi0177)
pm B18CXR
name's jack
Old Feb 9, 2005 | 06:22 AM
iggyracer's Avatar
Default Re: (Nishant)
this sounds like the probelems im having. Bump.
Old Feb 9, 2005 | 06:28 AM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaniquoi0177 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, I've heard P1 is the place to take it. Where exactly is it located?
Just south of Charlotte. Jack =
Old Feb 9, 2005 | 07:33 AM
Scotty B's Avatar
Unfortunatly compression check will not test the oil ring. I would also do a Leakdown test, and see what you get from that..
wego5typer#431
Apr 13, 2010 11:23 AM
turbo-crx
Jun 7, 2008 11:04 AM
kornerk12
May 1, 2007 12:09 AM
myguitar
Feb 23, 2006 07:00 PM
Azcheron
Jun 23, 2005 09:34 PM
