compression test results!!!!!
Old Jun 7, 2008 | 09:26 AM
turbo-crx's Avatar
Default compression test results!!!!!
well the problem i was having was with the car overheating. so i did a compression test this morning and i got perfect compresion except cylinder #2 it read 120, so i put a cap full of oil and it shot up to 170??? will this compression result in the car over heating? according to the haynes manuel it has bad rings, but there is no smoke and the car runs perfect.
the motor is as follows.
ls/vtec
wiseco 8:1
manely rods
arp headstuds
20 psi on crome pro
if you need more info please let me know.
also the car has a dual core radiator, 2 fans hard wired to the ignition, new thermostat and water pump. the car is a crx.
Old Jun 7, 2008 | 11:04 AM
dbiker207's Avatar
Default Re: compression test results!!!!! (turbo-crx)
u used to much oil, do the test again but use like 1/3 cap of oil.
skata89
Dec 21, 2007 11:13 AM
climb_on
Jul 29, 2007 03:40 PM
Azcheron
Jun 23, 2005 09:34 PM
mafay2
Nov 11, 2004 07:34 PM
1337 Si
Jan 14, 2004 07:03 AM
