2 wire plug above MAP sensor
Old Feb 8, 2005 | 11:16 AM
mymeatb18
Default 2 wire plug above MAP sensor
does anyone know what this is for and i think they only come on hfs cuz ive been looking for the connector that it goes with but i havent found another hf
Old Feb 8, 2005 | 11:36 AM
untitled's Avatar
Default Re: 2 wire plug above MAP sensor (mymeatb18")
If its the Evap purge solenoid, green wire and a black wire, take it off, it doesnt do anything important. Hell while your at it rip the charcoal canister out of there too. saves space.
Old Feb 8, 2005 | 11:40 AM
ssl2k's Avatar
Default Re: 2 wire plug above MAP sensor (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">If its the Evap purge solenoid, green wire and a black wire, take it off, it doesnt do anything important. Hell while your at it rip the charcoal canister out of there too. saves space.</TD></TR></TABLE>
Should you splice the wires together or leave them disconnected?
I agree with you to yank the charcoal can out....gives more vac sources
Old Feb 8, 2005 | 11:43 AM
untitled's Avatar
Default Re: 2 wire plug above MAP sensor (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">Should you splice the wires together or leave them disconnected?
I agree with you to yank the charcoal can out....gives more vac sources</TD></TR></TABLE>
I just left them unconnected and tucked away, dont leave them exposed tho, just unplug the thing and tuck the plug away somwhere inconspicuous.
Old Feb 8, 2005 | 03:37 PM
mymeatb18
thanks
kornerk12
Sep 25, 2007 07:23 AM
hotimportcrx
Nov 1, 2005 07:19 AM
Dunc
Mar 20, 2005 12:26 PM
Morhpeous
May 30, 2004 05:33 PM
NightHawk
May 4, 2003 06:30 PM
