Idle on the car is going crazy... cant stand it anymore. =(
Old Feb 8, 2005 | 08:30 AM
gtgoku's Avatar
Default Idle on the car is going crazy... cant stand it anymore. =(
well, I have notice that since saturday night when I got home from spinning the car is been idling relly low... to the point that most of the time it shuts off. I have changed alot of stuff and still turns off... spark cables and plugs, air filter fuel filter and all that junk. Im not throwing a cel but the car idles better at night than in the morning or afternoon. If you let the car stand for a bit the idle get better and doesnt have a problem. what do you think it is? alternator? thanks for everyone that can help in the matter.
thanks
Old Feb 8, 2005 | 09:58 AM
_BEN_'s Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (gtgoku)
What is it idling at before it dies? Have you adjusted your throttle body?
Old Feb 8, 2005 | 10:14 AM
red97gst's Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">What is it idling at before it dies? Have you adjusted your throttle body? </TD></TR></TABLE>
Please explain how to do this.I have been having the same problem with my 93 civic ex
Old Feb 8, 2005 | 10:38 AM
gtgoku's Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (red97gst)
nop I havent touch anything... just started doing it when I was coming from work one day at night. and hasnt stop ever since. i wonder what it is...
Old Feb 8, 2005 | 10:54 AM
gtgoku's Avatar
and the idling before it dies flutuates... as i come to stop sometimes its at 100 or sometimes its at less then that and the whole cars starts to shake... but it i stay steady it will go up by it self. now if I press the gas it would go back to like 100 and sometimes shut downs. some other time if I turn my lights on it will go up... its weird.
Old Feb 8, 2005 | 10:59 AM
_BEN_'s Avatar
Sometimes things will rattle loose.
With your car off. Twist the TB cam to WOT and you will see a little set screw with a nut on it. you will need a very small wrench and an allenwrench to adjust it.
Old Feb 8, 2005 | 11:01 AM
Lmgrcivic's Avatar
check your TPS sensor and your throttle cable
Old Feb 8, 2005 | 11:31 AM
gtgoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes things will rattle loose.
TB cam? where is that at?
Old Feb 8, 2005 | 11:32 AM
gtgoku's Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">check your TPS sensor and your throttle cable </TD></TR></TABLE>
where is that at?
Old Feb 8, 2005 | 11:55 AM
_BEN_'s Avatar
the throttle body cam(probably not correct nomenclature) is where your throttle cable attaches to your throttle body. The gold round looking thingy.
The tps sensor is on the exact opposite side of the cam. You will need a multimeter to trouble shoot this.
Old Feb 8, 2005 | 03:05 PM
aquarius's Avatar
my old car(ek hatch) had an identical problem. I put on a cold air and it was fixed. Im not saying thatll work for you..but it did for me.
Sounds like your engine is choking out, which is from lack of air. Theres probably a loose vaccum line or something of that sort. Just check to make sure everything is lined up.
Old Feb 8, 2005 | 05:49 PM
gtgoku's Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (TScribeSi)
actually makes sense! cause when its hot runs bad, when it cold it runs fine. usually thats the case when I drive at night,... no problem... when I drive in the morning and afternoon it sucks ***...
Old Feb 9, 2005 | 06:18 AM
aquarius's Avatar
My problem wasnt with the air temp...it was with the intake pressure. Before i got my cold air, i had a very cheap ghetto rigged short ram, which couldnt get a good flow. The new cold air flowed better, and therefore the engine didn't choke out anymore.
Basically.....your engine isnt breathing right. It could be an intake sensor that's loose though, making your ecu think the cars not breathing.
Check your vaccum lines and intake sensors...and i bet youll be able to find your problem
Old Feb 9, 2005 | 07:59 AM
Contraband's Avatar
I'd try the easy stuff first, may save you time and money. Get a can of carb cleaner and spray and wipe the throttle body and intake manifold. Could just be a bunch of junk in there.
Old Feb 9, 2005 | 08:58 AM
gtgoku's Avatar
Default Re: Idle on the car is going crazy... cant stand it anymore. =( (LS95eg)
yeah defently I will try that... thanks guys... will keep you posted of whats the outcome.
Old Feb 9, 2005 | 09:43 AM
Soccerking3000's Avatar
FYIits called the rotor on the t/b
freek21
Jul 11, 2012 07:23 PM
vrrodri
Sep 19, 2007 08:04 AM
Chris1112
Jan 2, 2006 09:35 AM
ciRcuitJerk
Jul 6, 2003 09:21 PM
