VIS cf hood + b18c = help!
Old Feb 8, 2005 | 08:17 AM
Viorent Grip! EG's Avatar
Default VIS cf hood + b18c = help!
first off...i searched...so search vultures....kick back
anyways, i just got a VIS cf hood and the fitment is just really odd....
problems are....
1. one of the predrilled holes dont want to line up properly
2. hitting the valve cover (b18c)
3. bc of 2 resulting in the hood not wanting to shut completely.
4. seems to be hitting on my radiator cap on my C&R.....errr?
i have no trouble at all with my stock hood....
i've searched and read that people either raise the rear with washers or special bolts, adjust the rubber bumpstops, adjust the latch, cut or sand away the skeleton where it is hitting....or a combination of.
some of the remedies are simple, but i just want to know if anyone has pics of how they modified their hood (skeleton).
where to get those "special" bolts that raise the rear, instead of extended bolts and washers.
i have no clue on the hole alignment, but if you have had that problem and have fixed it, please give me yo advice...
thanks
Modified by Viorent Grip! EG at 10:29 AM 2/8/2005
Old Feb 8, 2005 | 08:29 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: VIS cf hood + b18c = help! (Viorent Grip! EG)
if i remember right B18C5-EH2 had the exact same problem and did a write up about it. let me dig it up.
Old Feb 8, 2005 | 08:31 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: VIS cf hood + b18c = help! (AzntaggeR)
here ya go:
https://honda-tech.com/zerothread?id=572161
Old Feb 8, 2005 | 08:38 AM
damn brotha...i didnt expect that type of response..thanks alot!!!!
much appreciated
Old Feb 8, 2005 | 09:42 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Yeah you have the latest version of the VIS with the two bulky CF support rails on the underside of the hood, don't you?
I was lucky and got the second gen hood without those bulky supports, because the one you have hit my VC too.
My friends have just taken a drimmel and cut a notch in the support brace and they've had no problems.
Also I punched s few new holes in my rubber trim piece and used superglue to hold the clips in, so the trim looks OE.
Old Feb 8, 2005 | 09:48 AM
Default Re: VIS cf hood + b18c = help! (B18C5-EH2)
thanks B18C5-EH2
by any chance do you have any pics of how and what they cut away?
also, i saw in ur post about the vis hood issue that you redrilled holes for the hinges?
thanks alot
Old Feb 8, 2005 | 10:12 AM
VG! girL's Avatar
awww...don't worry....we'll fix it
Old Feb 8, 2005 | 01:08 PM
Default Re: VIS cf hood + b18c = help! (VG! gurlie)
a little bumpage....for some more input...
Old Feb 8, 2005 | 06:04 PM
bump..anyone else have any input?
thanks
Old Feb 8, 2005 | 07:34 PM
niterida's Avatar
I had to cut out the parts of my hood that were hitting the valve cover. The hood did not have any problems after being modified.
I spent literally hours making the hood fit just right. And it ended up taking hood pins to make it fit how I wanted
Old Feb 8, 2005 | 08:02 PM
Default Re: VIS cf hood + b18c = help! (niterida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niterida &raquo;</TD></TR><TR><TD CLASS="quote">I had to cut out the parts of my hood that were hitting the valve cover. The hood did not have any problems after being modified.
I spent literally hours making the hood fit just right. And it ended up taking hood pins to make it fit how I wanted</TD></TR></TABLE>
do u have any pics of what and how much u cut?
i would really appreciate it...
thanks
Old Feb 8, 2005 | 08:46 PM
niterida's Avatar
I never took pictures of the part I cut. sorry.
pm me for pictures of fitment
Old Feb 8, 2005 | 09:15 PM
reaction360's Avatar
i've never had to modify a vis cf hood for any honda. this is odd. does your vis hood have the "VIS" plaque riveted to the underside of the hood?
Old Feb 8, 2005 | 10:43 PM
Default Re: VIS cf hood + b18c = help! (reaction360)
yes it is riveted on the underside....its real...
what motor are u running?
Old Feb 8, 2005 | 11:52 PM
94_HATCH's Avatar
edit:nevermind
Old Feb 9, 2005 | 12:57 AM
drunknbass's Avatar
Default Re: VIS cf hood + b18c = help! (94_HATCH)
yea i sell cf hoods too. i sell the vis hood, and i also have another version which has a different underskeleton that doesnt run above the valve cover. that way it clears all swaps.
no cutting required
Old Feb 9, 2005 | 06:19 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">i've never had to modify a vis cf hood for any honda. this is odd. does your vis hood have the "VIS" plaque riveted to the underside of the hood?</TD></TR></TABLE>
Again there's only like one VIS hood that i know of that requires cutting to fit, and that's the newest version of the 1992-1995 civic hood if the car has a B series swap.
Trust me it has nothing to do with the car itself, because my front end is 100% perfect and the older VIS hood fits perfect on it.
I saw the manifest/shipping receipt from VIs for the hoods that didn't fit - they're definately VIS hoods.
Ldo
Mar 31, 2009 11:09 AM
RiceRacist
Nov 12, 2003 11:18 AM
Nighthawk GS-R
Oct 26, 2003 10:43 AM
Yamzz_EG
Mar 31, 2003 09:26 PM
CivicHb04
Jan 8, 2003 03:53 PM
