pilot bearing removal
Old Jan 16, 2002 | 09:07 AM
DragII's Avatar
Default pilot bearing removal
Is there a way to remove the pilot bearing without removing the flywheel, and without using a puller/slidehammer?
can it be pryed out w/ a screwdriver?
Old Jan 16, 2002 | 09:22 AM
C-speed's Avatar
Default Re: pilot bearing removal (DragII)
No, you cannot remove it without removing the flywheel.
Yes you can remove it without a puller/hammer, just use a large socket and a hammer, place it on the bearing and hit the socket.
Use the same method to put the new bearing back into the flywheel.
HTH
Old Jan 16, 2002 | 10:16 AM
DragII's Avatar
Default Re: pilot bearing removal (G3-TEG)
I stopped being a lazy ***, and just removed the flywheel...thanks for the confirmation though
Old Jan 16, 2002 | 10:48 AM
rtype11's Avatar
let me guess, you dont have 12pt sockets with 1/2" drive, well Snap-On is having a sale I think it'll only cost you an arm and a leg - if you have good insurance.
Old Jan 16, 2002 | 10:50 AM
dustin's Avatar
Default Re: pilot bearing removal (rtype11)
Heh unless you drill out the flywheel you have to take it off... since there is a lip that holds it against the crank...
Old Jan 16, 2002 | 12:27 PM
Aahj's Avatar
Default Re: pilot bearing removal (dustin)
by the way, you only need to torque it to 118 Nm six times.
It's pretty hard when the engine is out of the car.
later,
aj
Old Jan 16, 2002 | 01:02 PM
DR. ON POINT's Avatar
Banned
Default Re: pilot bearing removal (ajn)
engine is in the car.....I was gonna stop by today Antonio but I had to go to Fairafax and stand in a long line for my school books..........$350
Old Jan 16, 2002 | 01:06 PM
Aahj's Avatar
Default Re: pilot bearing removal (On Point EK)
I am still in high school, but next year, I will feel your pain!
it's that expensive?
damn!
I better start saving up now.
later,
aj
Old Jan 16, 2002 | 02:25 PM
DragII's Avatar
damn...david..
I was fine...just broke out the impact gun, and had the flywheel off in a couple minutes
manny81
Jun 19, 2011 01:14 AM
garyhgaryh
19
Jul 6, 2007 03:00 AM
lv6l
11
May 16, 2006 12:39 PM
HondAcura
Dec 22, 2005 10:37 PM
JAYGSR
Oct 5, 2004 05:56 PM
