Injector help (56k beware
Old Feb 7, 2005 | 10:03 PM
vegaskurt's Avatar
Default Injector help (56k beware)
I got these from a local yard off an integra, no idea what year. All four have the broken plastic part at the tip and its a two wire plug. Will these work for the MPFI swap or are they toast?
Old Feb 7, 2005 | 10:07 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Injector help (vegaskurt)
dont know much but i would say as long as the oring contact is not damaged and the plug is working electricly i'd say go for it.
Old Feb 7, 2005 | 10:08 PM
PHOBIA's Avatar
ouch,that looks im pretty bad shape.thats the best set you could find? only was to figure it out is to try it out.
Old Feb 7, 2005 | 10:15 PM
vegaskurt's Avatar
Default Re: (PHOBIA)
Yeah they need some cleaning, but the broken tips is what scares me, that and I thought that the SI mpfi injectors had three prongs on them...
Old Feb 7, 2005 | 10:22 PM
eda6's Avatar
Which local yard did they come from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">Yeah they need some cleaning, but the broken tips is what scares me, that and I thought that the SI mpfi injectors had three prongs on them...</TD></TR></TABLE>
all injectors clips have 2 wires
Modified by eda6 at 11:42 PM 2/7/2005
Old Feb 8, 2005 | 03:43 AM
thatbluecrx's Avatar
Default Re: (eda6)
i was led to belive if the plastic part is broken they are no good
Old Feb 8, 2005 | 04:14 AM
MENACE's Avatar
Default Re: (thatbluecrx)
To my understandig the plastic piece is not important, the injectors should work fine. Thruthfully they dont look all that bad. You might need a new O-ring on the top and bottom but other than that i say try um.
Also to be on the safe side, check to make sure that tips arent loose, dont force anything off, just gently try and remove any pieces that may fall into the motor.
a1320honda
Sep 23, 2007 01:06 PM
91dx-92ex
Jan 22, 2006 02:46 PM
huge230
Oct 1, 2005 09:39 PM
CRAZYHONDA
Mar 13, 2005 08:48 PM
sloboy_joe
Dec 2, 2004 08:29 PM
