head gasket???
Old Feb 7, 2005 | 07:23 PM
Egone's Avatar
Default head gasket???
i have a b18b and i was rebuilding it using new gaskets well long story short i used a brand new headgasket and torqued the head to the block then later took the head off the block is it okay to reuse the headgasket the engine never ran but ive heard storys of the head gasket warping ..... oh and its a 3 layer metal gasket
Old Feb 7, 2005 | 09:42 PM
Egone's Avatar
Default Re: head gasket??? (Egone)
ttt
Old Feb 7, 2005 | 09:45 PM
Neighborhood Superstar's Avatar
itll be alright. id be more worried about the head studs.
Old Feb 7, 2005 | 10:00 PM
Egone's Avatar
on that buying arp studs:D
Old Feb 8, 2005 | 06:56 AM
adaml2nv's Avatar
Default Re: (Egone)
yeah the headgasket should be fine, but you could spray some copper spray on there just incase of little dents.
and to arps
Old Feb 8, 2005 | 07:35 AM
ROOROWNS's Avatar
what does this copper sprqay look like or whats it called i need soe of that stuff. It just fills dents and **** in gaskets and beefs them up a bit?
Sean
Old Feb 8, 2005 | 07:40 AM
adaml2nv's Avatar
Default Re: (EG_Black_Hatch)
it comes in a spray can. you can buy it at any parts store (advance auto etc.) it just fills in the little imperfections on the gasket. it doesn't beef it up or anything unless you spray a **** load on it but you shouldn't do that. your only suppose to spray 2 thin layers on eash side.
it's called copper gasket spray i belive,
Old Feb 8, 2005 | 01:32 PM
Egone's Avatar
thanks guys
abiliojr
Jun 3, 2015 11:09 PM
Sienile
26
May 18, 2012 04:34 AM
Cantcatchme
Jan 5, 2012 03:26 PM
integrawow
Jan 24, 2009 06:39 PM
boomersz
10
Apr 11, 2007 04:37 PM
