b18a w/ YS1 cable tranny into 91 EF chassis, which clutch cable?
Old Feb 7, 2005 | 06:26 PM
mildly.interesting's Avatar
Default b18a w/ YS1 cable tranny into 91 EF chassis, which clutch cable?
yes, no one has covered this topic well, so I wanna know.
I had an a1 tranny w/ the LS motor, and the a1 tranny finally gave up the ghost after being forced to spin the tires in 3rd and 4th gears. I got a really good LS tranny and since it has become a highway racer, I figured the longer gears would do me good.
I swapped trannies to the YS1 with a new clutch and axles, and everything was coming along pretty good till I came to the clutch cable. Even if I pull up on the clutch arm as hard as I can, I still have about 1/2 inch to go before I can even pull the end onto the clutch arm. Even if I was able to get it hooked, I would have no adjustment whatsoever.
Do I need a 92-93 Integra cable? Am I crazy? Help me Lord!
Old Feb 7, 2005 | 06:50 PM
Old Feb 7, 2005 | 07:04 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b18a w/ YS1 cable tranny into 91 EF chassis, which clutch cable? (mildly.interesting)
90-91 integra clutch cable
Old Feb 7, 2005 | 07:15 PM
I'm pretty sure that's what came out of it, as it was connected to a 91 b18a with an A1 tranny from the same year.
can I flip the bracket on the top of the tranny
over and grind a little off of it?
Old Feb 7, 2005 | 07:43 PM
fourthgenhatchB17's Avatar
Default Re: (mildly.interesting)
I use a stock 88-91 SI cable with my YS1 LS trans.
Old Feb 7, 2005 | 07:44 PM
I think I have it now, you gotta bolt the bracket down last, that gives you a little more play in the cable...
Old Feb 7, 2005 | 09:00 PM
Bee17hatch's Avatar
i use my stock cable too i have ys1 trans out of 93 gsr works just fine.
Old Feb 7, 2005 | 09:09 PM
untitled's Avatar
Default Re: (Bee17hatch)
stock.
efcivic12
Nov 8, 2008 07:40 AM
ekay. jay
Jan 28, 2007 07:19 AM
synner
Aug 6, 2006 12:09 PM
5.0 Killa
May 1, 2004 07:11 PM
