si harness in 97 cx?
Old Feb 7, 2005 | 05:47 PM
redboost10's Avatar
Default si harness in 97 cx?
i bought a 97 cx with a b16a2 swap(p2t ecu). obviously everything was plug and play, but down by the ecu there was four wires that were soldered together from the engine harness to the harness in the car. two of the wires matched up with the colors and the other two were totally different colors. also vtec did not work.
can someone explain to me is this the right way to use that harness in an ek swap? could vtec be not working because of this or is it probably just something with the motor? thanks guys
Old Feb 7, 2005 | 06:02 PM
redboost10's Avatar
Default Re: si harness in 97 cx? (tgh99si)
im assuming its a si harness because it is plugged right into the p2t ecu without a jumper harness.
Old Feb 7, 2005 | 07:49 PM
redboost10's Avatar
anyone? help please
Old Feb 8, 2005 | 08:20 AM
redboost10's Avatar
ttt, please help out
Mad-Mike
11
Jun 23, 2011 03:40 AM
redboost10
Feb 10, 2005 11:20 AM
redboost10
Feb 8, 2005 08:20 AM
