how can u tell between JDM and USDM p72 ecu?
so there are not any #s on the ecu to tell the difference?...i dont have two ecus to compare it with...is the usdm p72 the same size as the usdm p28?...
You can look at the plugs to tell if its ob1, obd2 or obd2.2. My 01 usdm p72 is a small type ecu, so how would someone be able to tell if it is a jdm one or not?
JDM ecus are all obd1
The easiest way to tell is by the size but you can check the numbers too on the side...usdm I believe is p72-A03 where as the JDM is p72-003. HTH
Luserkid
Nov 27, 2003 04:02 PM
003, b18c5, detween, differance, difference, differences, ecu, fs, h22, honda, jdm, obd2, obd22, p72, usdm
