Which O2 sensor do I need??
Old Feb 7, 2005 | 03:04 PM
mafay2's Avatar
New User
Default Which O2 sensor do I need??
I have a 96 DelSol with Type R engine and running on Hondata P28 OBD I ecu.
So which model of O2 sensor do I need? One for the Type R engine or the one for SOHC Civic that run the P28 ECU? Or are they all the same?
Old Feb 7, 2005 | 03:14 PM
primeredbeast's Avatar
Default Re: Which O2 sensor do I need?? (mafay2)
if your running obd-1 i would get a four wire 02 that would work with your stock civic harness
Old Feb 7, 2005 | 07:34 PM
mafay2's Avatar
New User
Default Re: Which O2 sensor do I need?? (primeredbeast)
I still have the stock B16A DelSol harness. So I am not sure if I can get the 92-95 SOHC Civic, or do I need DOHC B series O2 sensor.
Old Feb 7, 2005 | 08:01 PM
chameleon's Avatar
all 02 sensors are the same from 92+ there is no difference what so ever.
Old Feb 7, 2005 | 08:09 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">all 02 sensors are the same from 92+ there is no difference what so ever.</TD></TR></TABLE>
Yep. I've used acura vigor and honda accord o2 sensors with my p28.
Old Feb 8, 2005 | 06:53 AM
mafay2's Avatar
New User
Default Re: Which O2 sensor do I need?? (eda6)
Thanks everyone!!
Now, anyone know a good place to buy one that is not as expensive as the OEM one?
Old Feb 8, 2005 | 08:01 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
pick up a bosch sensor from advance, checker, etc. if it breaks or fails, just take it back and get a new one.
Old Feb 8, 2005 | 08:57 AM
mafay2's Avatar
New User
Default Re: (MugenDude)
bosch has life time warranty on their o2 sensor?
Old Feb 8, 2005 | 09:06 AM
PrettyLude's Avatar
prostreetonline.com
Old Feb 10, 2005 | 09:19 AM
mafay2's Avatar
New User
Default Re: (PrettyLude)
I found out that the OEM one for Type R is like $100 more expensive than the OEM one for 96 SOHC civic. But the universal one for both Type R and SOHC civic are the same price and same part number. So what is the deal here?
Old Feb 10, 2005 | 10:11 AM
thumbtack's Avatar
Default Re: (mafay2)
the universals are the same price, cause they are UNIVERSAL... meaning they will work with any honda engine, and they will fall apart faster too... get a bosch OEM replacement. They will work alot better and less prone to faliure
Old Feb 11, 2005 | 07:56 AM
mafay2's Avatar
New User
Default Re: (thumbtack)
I found that the universal one is around $100 cheaper than the Bosch one. Is the Bosch O2 sensor worth the extra $?
Old Feb 11, 2005 | 08:23 PM
thumbtack's Avatar
depends on if you want to keep replacing the universal ones every couple months, or if you would rather have one that will last you a long time.
I just hear from other people that the universal O2s are just really crappy... I wasn't going to take any chances with my engine, so I went with the bosch OEM O2 and haven't had any issues with it.
Good luck with your decision. Just remember, the OEM is more expensive for a reason... it works properly. I can't say that about anything universal.
Old Feb 18, 2005 | 12:39 PM
platinum00's Avatar
what about the universal bosch ones. do they fail as well.
platinum
shredderkid322
12
May 8, 2012 06:10 PM
shredderkid322
Mar 31, 2011 01:40 PM
turbo sol
Sep 4, 2008 05:19 PM
4dek
10
May 28, 2008 02:49 PM
VtecDA9
May 20, 2003 09:46 PM
